QA1 Aftermarket K-member Problems?
Discussion in 'Suspension, Steering and Chassis' started by racerdude5, Jul 27, 2018.
  1. Duane
    Duane Well-Known Member
    634
    212
    Sep 29, 2009
    Ontario Canada
    View My Photos
    Local Time:
    7:14 AM
    Ok thanks I am off to work will measure tonight and post pics.
    Thanks for your help
  2. Duane
    634
    212
    Sep 29, 2009
    Ontario Canada
    View My Photos
    Local Time:
    7:14 AM
    Actually is that not a pic of the idler. We are going to measure the pitman correct?
  3. 5.7 hemi
    5.7 hemi FABO Gold Member FABO Gold Member
    1,964
    493
    Apr 18, 2009
    Local Time:
    7:14 AM
    No problem
  4. 5.7 hemi
    1,964
    493
    Apr 18, 2009
    Local Time:
    7:14 AM
    That is the idler. You want the pitman arm also?
  5. pishta
    pishta I know I'm right....
    13,433
    3200
    Oct 13, 2004
    Tustin, CA
    View My Photos
    Local Time:
    5:14 AM
    From the QA1 pic, it looks like they moved the idler arm mount forward 1" or you could correct it with a +1" idler arm. Hard to tell from the pic as it is not shot perpendicular to the center link. They could not move the steering as it would affect the existing steering shaft length.
  6. Duane
    634
    212
    Sep 29, 2009
    Ontario Canada
    View My Photos
    Local Time:
    7:14 AM
    Well I have installed the moog idler, so I figure that is not the problem.
  7. 5.7 hemi
    1,964
    493
    Apr 18, 2009
    Local Time:
    7:14 AM
    After re-reading this thread I went and looked at mine real close. My center link was higher on the drivers side by 1/2”. I’ve always had a problem with the TTI headers not fitting correctly, shimmed the drivers side engine mount by 3/8 and still had to dent the bottom 2 tubes to clear the pitman arm nut/stud.
    It had always bugged me, engine tilted to the passenger side, dented $800 headers and still the pitman arm stud would drag on the tubes.
    So my buddy stopped by with the flaming wrench, a bit of heat to the pitman arm, slight bend and now the center link is level and the pitman arm stud clears the tubes. Turning is still as it was so I’m calling done.
  8. Duane
    634
    212
    Sep 29, 2009
    Ontario Canada
    View My Photos
    Local Time:
    7:14 AM
    Any chance you could post a pic of the bent pitman arm.
    Years ago I used to hear of people heating and bending their pitman arm to improve toe pattern.
    Do you have any before and after pics?
  9. Duane
    634
    212
    Sep 29, 2009
    Ontario Canada
    View My Photos
    Local Time:
    7:14 AM
    Where can you buy a +1 inch idler arm. Never heard of that.
  10. 5.7 hemi
    1,964
    493
    Apr 18, 2009
    Local Time:
    7:14 AM
    I didn’t take a before pic, but here’s where I bent it.
    • Like Like x 1
    • pishta
      13,433
      3200
      Oct 13, 2004
      Tustin, CA
      View My Photos
      Local Time:
      5:14 AM
      Yeah, I never heard of one either. That was the point. Perhaps you could adapt from another application that had a longer idler? This one is +2" and fits B and E bodies....? (states that you must use with their matching longer pitman arm)
      Proforged Fast Ratio Idler Arms 102-10063
