question for the more intelligent
Mopar Performance Issues
  1. Triple x
    Triple x Member
    8
    0
    May 23, 2007
    Local Time:
    9:34 AM
    I just purchased a 1979 dodge D150 with a 318. It's a short bed, custom. Sorry, I haven't figured out how to post up a photo. My question is this. I purchased an eldebroch intake manifold and 4 bbl combo kit from summit. The carb is a 600 series, I don't have to remove the distributor to R/R the intake do I? Also , yeah I know I'm asking alot for a new guy, are the carbs pretty much preset and if not how do I adjust it?
    The previous owner stated that the engine has been rebuilt with a little bigger cam, not sure how much bigger. He also stated that it is 4.11 gearing and has a shift kit. That's about all I know of the truck other than a 2 year old paint job and the interior is in great shape. Anyway any advise would be appreciated greatly..
    thanks,
    Greg
  2. fishy68
    fishy68 Tyr Fryr's Inc. FABO Gold Member
    16,720
    742
    Jan 11, 2005
    Central, IL (Hooterville)
    Local Time:
    9:34 AM
    Greg I haven't tried just to r&r an intake, usually what I do gets more involved. But I think there should be no problem r&r'ing it without removing the dist. The carbs do come preset pretty close but they usually require fine tuning. I use a vacuum gauge to fine tune them. Just hook it up to a vacuum port that is active all the time and adjust for the highest reading then turn them in 1/8th turn each. Do this after you have warmed the engine up completely.
    If you don't have a vacuum gauge you can pick one up at Autozone or similiar parts house pretty cheap. Handy item to have.
  3. ramcharger
    ramcharger Dismember
    14,206
    111
    Nov 15, 2005
    Lakewood, Colorado
    Local Time:
    8:34 AM
    Remove the distributor. It'll make your life so much easier. As long as you don't pull out the oil pump drive gear, the distributor can only go in two ways. Just make note of where the rotor is ponting and where the vacuum can is pointed and that should get you close enough to fire it up. Once it's running, time it with a timing light and you'll be ready to go.
    I agree with fishy regarding the idle mixture screws except I just adjust for max vacuum and leave it there. As far as any other carb adjustments on the Edelbrock (it is an Edelbrock carb, right?) I'm not your man as I'm a Holley guy, but I'm sure someone else will chime in.
  4. rumblefish360
    rumblefish360 so close yet so far away
    33,789
    5773
    Jun 21, 2005
    New York, on a Island
    Local Time:
    10:34 AM
    You can go to Edelbrock.com and look up and down load and print the carbs instructions. Like said above, there pretty close OOTB. A rod and jet kit is set up for your carb number/size and at Sumitt, jegs etc......
  5. memike
    memike Super Moderator Staff Member FABO Gold Member
    48,910
    8935
    Jan 8, 2006
    on the hill
    Local Time:
    9:34 AM
    Glad to see you are enjoying this great site Greg, jump in and ask all you like.
    pull that dist, it is way easy.
  6. abodyjoe
    abodyjoe Well-Known Member
    19,381
    3753
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    10:34 AM
    you probably don't have to remove the dist. but it will be allot easier with it out.. as far as the carb goes it will probably be pretty close for a 318.. you'll have to see once its running though
  7. 66dartgt
    66dartgt Well-Known Member
    821
    2
    Jan 11, 2006
    chgo suburbs
    Local Time:
    9:34 AM
    You will need to remove the valve covers - the distributor is optional, but you'll want to be able to clean the gasket surface around that area. So, remvoing the dist will make that easier as well.
  8. Triple x
    Triple x Member
    8
    0
    May 23, 2007
    Local Time:
    9:34 AM
    thanks ya'll. My plan is to do the swap this weekend. I work on the popping afterwards if it is still there. If it is still there then that gives me a reason to purchase a set of eldelbroch heads, cam, and lifters, etc because I'll blame it on a burnt valve. Again thanks for the help and I suppose I'll pull the dist. YOu know what is funny? I started pulling wrenches when I was about 14,but spend 96 % of the time as a diesel mechanic for cummins engine. I have been out of the wrench pulling job for about 8 years and man oh man how much I have lost.
  9. 63dartman
    63dartman Well-Known Member
    2,237
    6
    Dec 11, 2005
    rio rancho, nm
    Local Time:
    8:34 AM
    I wanted to reply to this post but, I'm not very intelligent:)
  10. Guitar Jones
    Guitar Jones aka Angry Johnny
    2,954
    33
    May 24, 2004
    Deltona, Florida
    Local Time:
    10:34 AM
    Me four. :)
    I never pull distributors to do intakes, that's for Chevy people.
  11. 4mulaSvaliant
    4mulaSvaliant Well-Known Member
    1,577
    66
    Oct 26, 2006
    Virginia Beach Va.
    Local Time:
    10:34 AM
    Lmao!
  12. bschubarg
    bschubarg Well-Known Member
    287
    108
    Jun 13, 2005
    Local Time:
    10:34 AM
    What were you saying about intelligence....?
