D
Deleted member 38666
Guest
Need more help. I bought a 273 Hipo rebuild kit from Falcon Performance to rebuild my 273 2bbl 4-valve relief piston engine. The HiPo Pistons are manufactured by Packard. The machine shop said it is common, on these old engine blocks whether Mopar, GM, Ford, or whatever, that the tolerances are not as truly accurate as modern day machining. Anyway, they told me, prior to boring the bock to the 0.030 over, that the block needed to be decked at 0.015. I am using the aluminum cast pistons from Falcon Performance/Packard as previously described, and the heads HAVE NOT been planed. I am installing a Racer Brown 210 duration/.430/.430 lift cam with OEM valve springs, solid lifters, and OEM rockers on the 273 un-planed heads. The new Pistons have the 2-valve relief half dome, and the Felpro head gasket has a thickness of 0.057. My question is, with the 0.015 block decking, will I have valve to piston clearance issues regarding the described parameters. I do not know if Falcon Performance HiPo Pistons built by Packard are manufactured to OEM height, but, assuming they are, with a 0.015 block decking, no head planing, and the higher lift cam, will I have a collision between the valves and pistons. I think I have all the info listed, but if I forgot something, ask away. Appreciate your help greatly. Thanks for the help. Old Dart 66
