Questions for those that have moved their leaf springs in...
Suspension, Steering and Chassis
  1. dart_68
    dart_68 Well-Known Member
    623
    416
    May 25, 2017
    Lakewood, CO
    Local Time:
    10:02 AM
    I was looking at my '73 Duster and contemplating the work required to move the leaf springs inboard. If I remember correctly, the new location puts them directly under the frame rail.
    Where did you move your exhaust pipes as mine run under the frame?
    Did you keep the stock gas tank or go to a trunk mounted fuel cell?
    Thanks.
  2. mopardude318
    mopardude318 Well-Known Member
    9,654
    813
    Jan 7, 2005
    Gilroy, Ca
    Local Time:
    9:02 AM
    I kept the stock tank. I don't like tailpipes going over the axle and out the back. I like turndowns in front of the axle.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • draginmopars
      draginmopars Well-Known Member
      1,260
      335
      Jan 25, 2013
      Smyrna,tn
      Local Time:
      11:02 AM
      72 swinger-trunk mounted fuel cell
      3" exhaust
      • Like Like x 1
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        18,547
        6682
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        11:02 AM
        That's a 3 inch relocate.
        FYI
        There is a 3/4" relocate that leaves plenty of room for 3" tailpipes. I fit 325/50-15s into the factory tubs of my 68 Barracuda with those. It was tight at my lowered ride height. I had to get creative with the BFH in a couple of places on the inboard side, and on the outboard side, I curled the lip up. It works fine in straightline work, but I have to tone it down in the turns. I think it would be fine at factory ride-height. I narrowed the rear to use the common 15x10/4.5 BS wheels.
        • 6pk2goDemon
          6pk2goDemon Mopar Mod Staff Member FABO Gold Member
          11,277
          2579
          Mar 1, 2008
          Arizona
          Local Time:
          9:02 AM
          I have the stock gas tank w/ relocated springs & exhaust tips to the rear under the bumper. The tailpipe is a tight fit on the passenger side, but a good muffler shop shouldn't have trouble...
          • inertia
            inertia Well-Known Member
            3,218
            529
            Feb 4, 2011
            Victoria B.C. Canada
            Local Time:
            9:02 AM
            As above, you'll have to find a muffler shop that "wants" to do it, some can't.
            • Dragonsteel
              Dragonsteel Well-Known Member
              198
              223
              May 12, 2015
              Missouri
              Local Time:
              11:02 AM
              This was a Jeg's 2.5" exhaust kit for the A-body's ran over the axle and outside the leaf springs. I used Cuda muffler mounts to hang the exhaust tips from.
              Some cutting and modifications will be required to get it to fit right.
            • 67dartgtgo
              67dartgtgo FABO Gold Member FABO Gold Member
              1,085
              492
              Nov 9, 2012
              Mass
              Local Time:
              11:02 AM
              The offset spring hanger kit moves em in approximately 3/4” on each side. As AJ says you should have plenty of room with this to go over the top and a pretty straight shot to the bumper. My 2 1\2” has tons of room. I’m running 275/50/15s with no rub issues on my 67 dart.
            • famous bob
              famous bob mopar misfit
              16,838
              6522
              Aug 14, 2011
              okla
              Local Time:
              11:02 AM
              You two guys have got me wondering if my ebay gas tank is wider than stock, I have the 3/4" relocaters and don't have room for any tail pipes, " not that I want them. deadweight!
            • inertia
              3,218
              529
              Feb 4, 2011
              Local Time:
              9:02 AM
              It kinda sounds like you don't want tailpipes to start with, so if you get together with a shop that doesn't want to do them, you're all good.
              This usually means turn downs in front of axle, and lotsa crap off the road, blowing dirt all over otherwise nice cars. Cruise thru a show and shine with turndowns, where folks have spent hours shining/detailing their car, and your car becomes the target of every owner with a Key. .
              I've actually seen cars with turn downs refused entry to the lot of a s/shine, and applaud it.
            • mopardude318
              9,654
              813
              Jan 7, 2005
              Gilroy, Ca
              Local Time:
              9:02 AM
              Sitting around in a lawn chair isn't my thing.
              • Agree Agree x 1
              • famous bob
                16,838
                6522
                Aug 14, 2011
                okla
                Local Time:
                11:02 AM
                Nor mine, I was a judge in a car show once, never again, and probably wont ever go to one again. My pipes are big enough to not stir any thing up that is on the pavement anyway (not much backpressure) , no dirt road driving for it either, so that argument is moot . Key my car and you`ll get a hollow point.
