SgtLee511
I forgot does the oil feed bolt go at the top right
IMO it doesn't matter. There isn't enough oil coming through that bolt to do anything. Technically, it goes into the hole that breaks through into the lifter valley.
I want more oil on the timing chain. So I drill a small hole in the cam plate where it covers the main oil feed gallery. That puts oil on the timing chain. Since I run a gear drive, I make damn sure there is oil on the gears and that's how I do it.
it goes on the top hole that is drilled thru to the lifter valley! the other 3 holes are blind! It most definitely adds more oil to the timing set, if not please explain why Chrysler drilled thousands of them. and if u have it why not use it? I do not like the idea of only useing 3 bolts, same reason I use all 20 headbolts
sorry, I meant what the others said.. it's the only one you can stick a ice pick through.Ok, the answer is it goes on the bottom, passenger side of the block. Truth is, most don't even come with a hole in the bolt. However, if you want more oil, leave that bolt out. I've done this more than once and never had an issue.
Apologies for the thread hijack.
Hey YR, do you have any pics of where you do this? Or should I just shoot you a PM on this. I'm about to order the milodon 13600 setup for my 360.
-Aaron
