1. RammerJammer75
    RammerJammer75 Well-Known Member
    1,306
    1616
    Aug 28, 2020
    Kingsport, TN
    Local Time:
    3:36 AM
    Browsing through Facebook marketplace for stuff I don't need, I came across a 318 the owner swears is a race block (casting number 4104230-318-4). Doing some research, several sites list it as a race block except for the site (mopar casting numbers) says it is a '76-'84 standard block. I wonder what the deal is. I also did read a similar post on FABO about these casting numbers and that one stated it was more than likely a standard block. I know the X on the front of the block is a dead giveaway but I'm still curious about your thoughts on the block and why there would be so much conflicting date on that specific casting number.
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    58,902
    46047
    Jan 18, 2006
    Iowa
    Local Time:
    2:36 AM
  3. 318willrun
    318willrun Utube channel 318willrun
    17,251
    19409
    Sep 13, 2013
    I'm here
    Local Time:
    2:36 AM
    I always thought every 318 was a race block..... :realcrazy:
    • Like Like x 11
    • Agree Agree x 3
    • yellow rose
      yellow rose Overnight Sensation FABO Gold Member
      28,537
      24967
      Jun 19, 2015
      Central Washington
      Local Time:
      12:36 AM
      Ok, that made me LOL.
      • Agree Agree x 4
      • Like Like x 2
      • j par
        j par Well-hung Member
        27,882
        15308
        Jul 2, 2014
        Portland Oregon
        Local Time:
        12:36 AM
        I have one of those 318 "race blocks"...
        Well at any rate it has the number sequence I believe that you're talking about because when I looked it up there was a certain lookups that said race block with its particular numbers. Of course it doesn't have an x on the front of it. It did come out of a cop car and had 360 heads and a windage tray.
        • Like Like x 1
        • Demonracer
          Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
          5,035
          3023
          Jan 31, 2010
          Cleveland, Texas
          Local Time:
          2:36 AM
          Many years ago, Popular Hot Rodding magazine built up a 73-74 340. The suggested using a 318-3 or 318-8 crankshaft because they claimed they were a truck shaft & were stronger. I don't believe all of the BS the magazines publish because they can print whatever they wish & it's up to the general public to prove or disprove it. By the time their lawyers get through, whomever disputed them is broke.
          • Agree Agree x 1
          • yellow rose
            28,537
            24967
            Jun 19, 2015
            Central Washington
            Local Time:
            12:36 AM
            I used several of those cranks. Don’t know if they were any stronger because I never broke a crank, but at that time I could find those dirt cheap.
          • Locomotion
            Locomotion Well-Known Member
            3,192
            745
            May 31, 2004
            Florida
            Local Time:
            3:36 AM
            I think the main difference between a forged 318/340 crank and a forged 318 truck crank is that the rod journals were either solid or not drilled all the way through.
          • gregcon
            gregcon Well-Known Member
            697
            721
            Dec 20, 2009
            Local Time:
            2:36 AM
            The older I get, the more I despise writers. You come to realize that their talents lie in writing, not in actually doing or even knowing.
            • Agree Agree x 5
            • Like Like x 1
            • replicaracer43
              replicaracer43 Grumpy Old Man
              4,921
              4269
              Oct 10, 2008
              Local Time:
              2:36 AM
              The regular 318 casting number was used on the "X" blocks, but its likely not a actual race block
            • 67Dart273
              67Dart273 FABO Gold Member FABO Gold Member
              48,788
              16931
              Oct 14, 2010
              Idaho
              Local Time:
              12:36 AM
              Many years ago that mag or maybe CarCraft had a couple of "project" series, one was a yellow 32-ish coupe. I remember "shortening the driveshaft" they had some dope saw the tube and WELD THE TUBE back together someplace in the middle
              I "would have had proof" of B.S. if I'd saved a little announcement I read. "Some magazine" back in the 70's way in the back, was a little boxed in area in not-very-large print. this was one of the popular mags, Hot Rod, Popular Hot Rodding, or Car Craft.
              What this said in essence, is "when we test cars and publish track times"................."and we feel the weather, the car, the driver was not up to what we think it should be, we factor times an mph"
              RIGHT THERE ........."We are liars"
              • Like Like x 1
              • RammerJammer75
                1,306
                1616
                Aug 28, 2020
                Kingsport, TN
                Local Time:
                3:36 AM
                Ok, as stated in post #1 the research I did brought up conflicting data (posts on FABO, listing of casting numbers, etc.). I am still wondering why this data is so conflicting. I've seen evidence of this casting number with no X, no 4 bolt mains and yet people still insist it's a race block. Makes no sense.
                • Like Like x 1
                • perfacar
                  perfacar Well-Known Member
                  1,092
                  285
                  Mar 1, 2006
                  renton,wa
                  Local Time:
                  12:36 AM
                  back to the 318 truck crank, in my mopar race manual, states, 318 truck crank is nitrate hardened journals. also , it's out of a 318 poly engine. mopar started this in 1965, with 273,
                  • Agree Agree x 1
                  • Bobzilla
                    Bobzilla Well-Known Member
                    1,003
                    780
                    Aug 10, 2017
                    Livonia, Michigan
                    Local Time:
                    3:36 AM
                    There is conflicting information because every time a question is asked about these old blocks tons posts talk about regular old 318 blocks.
                    The fact is when the old race blocks were cast they used an existing casting number. So the only real way to know for sure it is a race block is the other markings on the block itself.
                    If it has the large X or R on the front of the block it should be a real race block.
                    Check out post 76 in this thread for photos of real race X block with same casting number you posted, except it was a -5 casting instead of -4:
                    Mopar R1 block
                    • Thanks! Thanks! x 1
                    • gregcon
                      697
                      721
                      Dec 20, 2009
                      Local Time:
                      2:36 AM
                      Years ago, Popular Hot Rodding ran an article on the Magnum Force (or Alterkation?) front ends for the A body Mopar. In the article, they bragged about how the suspension setup shaved something like 225lbs. off the nose of the car. I don't recall the exact number, but you get the idea.
                      It seemd like bullshit to me, and I happened to have an entire 1973 disc brake k frame with brakes, control arms, steering, etc sitting out in the shop. So I hooked it up to my scale and it weighed - covered in dirt and grime, even - 7 lbs more than the poundage the article said was saved.
                      So I went on the PHR website forum and posted pic of the K frame on the scale and politely (seriously, not being a dick) asked if they had made a mistake. Their response? They deleted my post without any comment!
                      • Like Like x 2
                      • Krooser
                        Krooser Reform School Graduate
                        3,152
                        2658
                        Jul 19, 2015
                        Central Wisconsin
                        Local Time:
                        2:36 AM
                        A Ford 352 FE block will have the same casting # as a 427 Ford . Stuff happens.
                        • Agree Agree x 1
                        • Rocket
                          Rocket FABO Gold Member FABO Gold Member
                          2,159
                          334
                          Apr 22, 2005
                          Manchester, CT
                          Local Time:
                          8:36 AM
                          Pictures of a race block including the common casting number of other 318's.
                          Note X of right side of timing cover, extra meat in the timing cover area, X in the bellhousing area and the extra meat in the main saddles. Another clue is many of them came without the dipstick tube hole drilled.
                          P1040457.JPG P1040464.JPG P1040466.JPG P1040467.JPG P1040468.JPG P1050256.JPG
                          • Like Like x 2
                          • Agree Agree x 2
                          • RammerJammer75
                            1,306
                            1616
                            Aug 28, 2020
                            Kingsport, TN
                            Local Time:
                            3:36 AM
                            Interesting. I've never seen an X block with 2 bolt mains, I always thought they were 4 bolt.
                          • yellow rose
                            28,537
                            24967
                            Jun 19, 2015
                            Central Washington
                            Local Time:
                            12:36 AM
                            I’ve had several of them, all 2 bolt. The X block for my junk car is 2 bolt. The R block I have for the 3.79 stroke W2 junker I’m doing is a 2 bolt block but it’s getting 4 bolt caps.
                            • Blucuda413
                              Blucuda413 Well-Known Member
                              143
                              103
                              May 20, 2012
                              Alexandria, Louisiana
                              Local Time:
                              2:36 AM
                              They came in both 2 bolt and 4 bolt. I've got a 4 bolt that I've been using for better than 20 years. Mine is currently 4.1 bore but will go to 4.125 safely. Oil tube hole not drilled.
                            • Tooljunkie
                              Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                              18,641
                              19831
                              Jul 22, 2017
                              Manitoba
                              Local Time:
                              2:36 AM
                              I have 2 with that casting number. One has a 318 poly crank in it. It was built for a 59 dodge to keep original manual transmission. The other came out of a 76 van.
                            • yellow rose
                              28,537
                              24967
                              Jun 19, 2015
                              Central Washington
                              Local Time:
                              12:36 AM
                              You have an X or an R block?
                            • Blucuda413
                              143
                              103
                              May 20, 2012
                              Local Time:
                              2:36 AM
                              Sorry bout that, it is an X block.
                              • replicaracer43
                                4,921
                                4269
                                Oct 10, 2008
                                Local Time:
                                2:36 AM
                                You dont have race blocks, you have regular 318s
                              • m79ded
                                m79ded Well-Known Member
                                47
                                17
                                Nov 21, 2017
                                NY
                                Local Time:
                                3:36 AM
                                I also have an X block in my 73 Duster and is @ 4.10 bore and might need to go a bit bigger, what's generally safe?
