[SOLD] Race Version W-2 Heads
JoeDragster
Longview, Texas
These are ready for a new home. Let’s make a deal!
These are the dual pattern, long valve race version W-2 heads from around 1976. These come with all the valves, springs and retainers. No pedestals, shafts or rockers are available.
These valves look to be in great shape with no visable damage.
Valves are 2.220 and 1.600
These will work on standard 59 degree blocks.
These require the pedestals for the rocker shafts.
Included is a receipt from the machine shop where they were cleaned and pressure tested. These are not stock heads and have been “worked”. I do not know any flow numbers.
These heads were also magnafluxed! Very small cracks near the spark plug hole probably from over tightened plugs.
$800 and shipping is available.
I accept PayPal and you’re welcome to come pick them up I. Longview, Texas 75605.
So do these use the blocks for the rocker arms non-shaft Mount right the Econo is for the shaft mount right?
