Racing the 318
Mopar Racers Forum
  1. Ceedawg
    Ceedawg Well-Known Member
    378
    243
    Aug 2, 2016
    Va
    Local Time:
    12:48 AM
    Has anyone raced the 318 2 barrel engine in stock form? Looking at this engine in NHRA Stock class. Looking to get 300 HP, would put the car around .70 under in the N-O or P class depending on the weight of car. Just hitting the index needs 238 HP. As you know no mods to heads other than any valve job, stock lift cam, any duration, stock intake. Reason is I have at least 10 318s and two so so 340s. Any input would help.
    How do I change the header to racing tHe 318?
  2. motorpirate
    motorpirate serial mopar owner
    596
    407
    Nov 4, 2007
    northern KY
    Local Time:
    11:48 PM
    https://www.forabodiesonly.com/mopar/threads/2018-small-block-race-join-the
  3. Ceedawg
    378
    243
    Aug 2, 2016
    Va
    Local Time:
    12:48 AM
  4. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    41,129
    12604
    Jun 21, 2005
    New York, on a Island
    Local Time:
    12:48 AM
    That’s weird. Search @318willrun and click on his posts, then at the bottom of the list, click all the threads he started. It’s somewhere in there.
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      73,365
      48886
      Jun 7, 2010
      Georgia
      Local Time:
      12:48 AM
      Plenty of 318s came with four barrel carburetors. Any reason you cannot run one? IMO, regardless of camshaft duration, you'll never reach 300 HP with a two barrel.
    • 318willrun
      318willrun Utube channel 318willrun
      17,280
      19474
      Sep 13, 2013
      I'm here
      Local Time:
      11:48 PM
      my friend at the drag way raced this truck in stock eliminator with 318 4bbl. In the mid 90's he was class record 4 years straight with it. Weighed over 4010 lbs with driver
      He ended up going 360 in both his trucks in stock eliminator. This is his other truck with 360. This truck went a best of 11.38 @ 115 mph. When he is racing class, he has another hood class legal.
      • Like Like x 3
      • motorpirate
        596
        407
        Nov 4, 2007
        northern KY
        Local Time:
        11:48 PM
      • 70aarcuda
        70aarcuda Master Hoader of SBM FABO Gold Member
        16,349
        5034
        Jan 16, 2005
        las vegas
        Local Time:
        9:48 PM
        He is trying to run NHRA stock eliminator with a Duster...no 318s with 4 barrels came in Dusters...
        I have not seen any 2 barrel 318 Dusters in Stock....i will ask some "friends" who race stockers what they know..
      • Ceedawg
        378
        243
        Aug 2, 2016
        Va
        Local Time:
        12:48 AM
        I heard back from a couple of stockr guys who said, good luck, factored hp to high. Lucky to get 250 out of the combo. I'll flow a carb-intake-head to see what I come up with later down the road
      • 70aarcuda
        16,349
        5034
        Jan 16, 2005
        las vegas
        Local Time:
        9:48 PM
        read your post over at ClassRacer.........
