1. Coyote Jack
    Coyote Jack Member #55, I'm old FABO Gold Member
    8,313
    2042
    May 22, 2004
    Baxters Corner N.B. Canad
    Local Time:
    1:51 PM
    Has anybody got a part number for a 20 pound radiator cap that will fit a stock 26 inch 2 core 340 radiator? This 16 lb is not doing the job.
    Jack
  2. brian6pac
    brian6pac Well-Known Member
    3,479
    1986
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    12:51 PM
    I think you have other problems
  3. ScampMike
    ScampMike Despicable Damn Yankee FABO Gold Member
    34,094
    8859
    Oct 26, 2015
    all Mopar driveway
    Local Time:
    12:51 PM
    yeesh - no need to get all personal and everything with the guy... what'd he do to you!? :lol:
  4. brian6pac
    3,479
    1986
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    12:51 PM
    LOL
    you know what I mean
    I ran into the same thing on a 11:1 motor, bigger fan helped, bigger rad fixed it.
  5. Coyote Jack
    8,313
    2042
    May 22, 2004
    Local Time:
    1:51 PM
    The problem is that it spits out coolant when I turn the car off. It does not overheat while driving. It runs at 185 to 195 depending on the day.
    Jack
  6. 72Dart6pack
    72Dart6pack Harder Better Faster Stronger.
    2,873
    1903
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    12:51 PM
    Put a overflow tank on it.
    • Agree Agree x 2
    • TrailBeast
      TrailBeast Slightly Twisted Member
      19,500
      5928
      Mar 11, 2011
      Arizona
      Local Time:
      9:51 AM
      It could even just be a bad cap, as there is no reason for a 16lb cap to do that unless it's getting hotter than that.
      (well, unless there is a compression leak in the block somewhere)
      IMO, replace the 16lb cap, and if that doesn't do it then a recovery system.
      Remember, a higher pressure cap will just put that much more pressure on all your hoses, radiator and heater core.
    • RedFish
      RedFish Well-Known Member
      23,052
      2002
      Sep 5, 2007
      Local Time:
      11:51 AM
      My 67 273 did the same thing if I filled the system to the cap. Somewhat embarrassing to roll in at the cruise-in and dump a pint. One solution is leave the fill level low, barely cover the tubes like the factory prescribed back then. Then it dumps a little air if anything, and the air adds to the rusting and all that is why they added a reservoir. That's why I added a reservoir to my 67 too. I found the translucent plastic reservoir quite beneficial in that I see the cooling system condition at a glance, while pulling oil dipstick, whatever.
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
      15,435
      4489
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      11:51 AM
      My 7 pounder has never let me down, but I do have an expansion tank. It came off a 73 Dart. I had to drill a hole for the bottom locator, that's all.
      Course it seldom gets over 37*C around here. That'd be 98.6,lol. I've never seen 40(104*F) in Manitoba. I seen it in BC tho, back in 75 when we were crossing the Great Divide; on motorcycles. Liquid Cooled Water Buffaloes they were. Ugly, heavy, ill-handling, not particularly powerful, but they'd probably run in an iron smelter; for a bit at least. Yeah, they didn't care how hot it got or how fast we rode, those temp gauges barely moved. Good memories right there.......When we got to the top, we saw a lot of bikes and cars, waiting for the airtemp to drop.I think the thermometer was showing 104. We had no idea; we had the road to ourselves and we were booking it. And no helmet laws in those days either. Goggles in July are kindof mandatory tho,lol. Some of those bugs I swear weigh over a pound at the speeds we were traveling.Hyup, good memories.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      10,449
      1291
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      11:51 AM
      There are 2 different style rad caps. The 1 with out the recovery system has a single rubber in it. The recovery 1 has 2 rubbers. Kim. Oh ya. Ha ha
    • yellow rose
      yellow rose Doctor of Thinkology.
      15,549
      12116
      Jun 19, 2015
      Living on the razors edge
      Local Time:
      9:51 AM
      I agree 20 pounds is a lot of pressure, especially for most hose clamps.
      TB is correct. I have had brand new caps puke like that. I ASSumed that they had a bad run of springs or something. When you shut the engine off, the temp goes up. As much as 50 degrees. The coolant expands and it pushes past the cap, which I'm sure you know. When it can't expand it builds pressure and overcomes the cap.
      I'm thinking 20 pounds is asking for a failure somewhere else.
      • Agree Agree x 1
      • Coyote Jack
        8,313
        2042
        May 22, 2004
        Local Time:
        1:51 PM
        Thanks everybody, I'm going to try a new cap first and if that doesn't do the trick then I guess I better find room for a puke tank.
        Jack
      • AJ/FormS
        15,435
        4489
        Jan 19, 2014
        Local Time:
        11:51 AM
        You know they make cap testers , right?
      • oldkimmer
        10,449
        1291
        Nov 11, 2006
        Local Time:
        11:51 AM
        But does he have the right cap for his system? Kim
      • RustyRatRod
        RustyRatRod 30 Degrees Outta Whack FABO Gold Member
        49,167
        15370
        Jun 7, 2010
        Georgia
        Local Time:
        12:51 PM
        O'Reilly Murray part # 7020.
        Damn yall, the dude has a blower on his engine. Might be a little different than the average bear, ya think?
      • Coyote Jack
        8,313
        2042
        May 22, 2004
        Local Time:
        1:51 PM
        Thanks Rob.
        Jack
