Radiator emplacement picture
moparcuda
quebec
Hi,I built a 67 cuda with 6-71 451 and I want the radiator emplacement with the electrics fans,,thank you
@Coyote Jack has a blower on a small block car. Maybe he'll chime in with some pictures. Not quite the same, but might give you some ideas.
I ended up cutting the middle of the rad support out and mounting the rad to the front of the support. I originally had a stock style radiator in there but it was a 2 row setup and was not up to the task. I now have a Champion 3 row that works well. I also switched from electric fans back to mechanical as it allowed for more space and was easier on the stock electrical system witch was being over taxed with the electric fans. I will get a couple of photos for you a little later this morning.
Jack
