Radiator Hose
moparstud440
Keymar, MD
Anyone happen to have a setup similar to mine and have an upper radiator hose part number that would work for my application? The radiator I have is out of a Ford Aerostar mini van so the top inlet is on the passenger side. I've been using my current setup for awhile and it's been fine, but I'd like to have a 1 piece hose. Hose measures roughly 22" long.
FWIW, I have a 26" Bbody radiator in my car. It's clear this hose does not have the reach you will need. You might be better off taking your assembled hose (or even a stiff wire bent in its shape) to a parts store and try to match it up.
Thanks for the replies. I'm going to give the Gats 20229 a try as it looks like it would work.
Looks similar to mine. I used a '68 B-body big block hose and had to trim it.
