Rattle can primer
Mopar Body and Trim
  1. Roadart
    Roadart Well-Known Member
    167
    33
    Jun 18, 2018
    Escalon ca.
    Local Time:
    6:28 PM
    Right now my 72 dart is flat black. I plan on taking it down to metal to see what is under the paint,(body filler etc) I have a small shop air compressor with no water filter. Will spray can primer work before paint? does the primer need to work with the paint?
  2. RustyRatRod
    RustyRatRod 30 Degrees Outta Whack
    55,632
    24271
    Jun 7, 2010
    Georgia
    Local Time:
    9:28 PM
    Yes it will but it will be really expensive.
  3. 1969383S
    1969383S FABO Gold Member FABO Gold Member
    4,780
    1945
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    9:28 PM
    Don’t do it! Use an epoxy. The rattle can crap just sucks in moisture and causes you more grief. Spend the same $ for a cheap filter! JMO.
    • Agree Agree x 6
    • 1969383S
      4,780
      1945
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      9:28 PM
      You can get rattle can 2 part epoxy, just pop the second piece, usually from the bottom. It must be used quickly, just stay away from the home store/auto parts primer stuff!
      • Agree Agree x 2
      • Like Like x 1
      • fishmens67
        fishmens67 Well-Known Member
        6,275
        3262
        Nov 10, 2012
        idaho
        Local Time:
        8:28 PM
        Very good advice ! I hope the OP takes it.
      • mopowers
        mopowers Well-Known Member
        4,208
        1318
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        6:28 PM
        I used rattle can primer/sealer on my wheels before laying down some single stage urethane. They turned out fine. It's probably not ideal, but sometimes 'not ideal' is good enough to work just fine.
        • Agree Agree x 2
        • Like Like x 1
        • harrisonm
          harrisonm Well-Known Member
          2,237
          1725
          Jan 16, 2005
          Topeka, KS
          Local Time:
          2:28 AM
          RRR is right about the expense. Spray cans would be a very expensive way to do it.
          1969383S is also right. You really do want to protect bare metal with epoxy primer. Plus you cam do filler work right on top if the epoxy when it is scuffed with some 80 grit.
          Here is my $0.02. Go to TP Tools at 1/2'' Coalescing Air Filter .html?b=d*8081
          They sell a water separator that does a great job keeping the air dry. it takes reusable filter cartridges that look kind of like toilet paper rolls. They can be dried out and reused many times. Make sure you buy a few extra cartridges. This thing works great. I have one.
          • Like Like x 3
          • Fred Scigliano
            Fred Scigliano Well-Known Member
            10,000
            10430
            Nov 26, 2017
            NORTH DAKOTA
            Local Time:
            8:28 PM
            You can get disposable filters that screw on to your spray gun not expensive.
            My neighbor did rattle can primer on his truck took it to the paint shop to have it painted and 2 years later his paint is falling off as well as the primer.
            1969383s has some good advice.
            • Agree Agree x 3
            • barbee6043
              barbee6043 barbee 6043 FABO Gold Member
              11,166
              3812
              Jul 20, 2008
              Shepherd, Texas ( SE Tx)
              Local Time:
              8:28 PM
              I agree get some sort of inexpensive water trap , also you can also get a $5 little plastic bulb type trap to use at your gun, it helps. The foundation of your job will be the quality of the metal surface and using a good epoxy primer. I agree stay away from the auto parts store crap. Only thing I have seen decent is a large can made by MarHyde and I think they called it a self etch. I have used it as a spot primer on a few small spots with OK results. The stuff is expensive like $35 for a large spray can. BUT!!! Don't try to prime your car with stuff out of a spray can!!!! Period. OK?
              Like many others on here, I like Southern Polyurethanes stuff. You can get an epoxy primer that makes 2 gal with the activator. Also you an Mix a little reducer and use it as a sealer over your filler, you applied on top of the epoxy primer. So you spend maybe $250 for this.
              So for that $ you have enough epoxy to primer the whole car very well top bottom inside out and seal it with great quality product.
              • Agree Agree x 1
              • j par
                j par Well-hung Member
                17,128
                8313
                Jul 2, 2014
                Portland Oregon
                Local Time:
                6:28 PM
                Don't forget to tell people to use a respirator when using this kind of paint...
                • Agree Agree x 3
                • Fred Scigliano
                  10,000
                  10430
                  Nov 26, 2017
                  NORTH DAKOTA
                  Local Time:
                  8:28 PM
                  So true j par I've been painting for years and now trying to paint my Scamp I get sick even in a paint booth with a paint mask on.
                  • Thanks! Thanks! x 1
                  • Agree Agree x 1
                  • 1969383S
                    4,780
                    1945
                    Jan 8, 2012
                    Cumming, GA.
                    Local Time:
                    9:28 PM
                    Good post. I have used them as well. Not a painter but understand! They are relatively cheap.
                    • Agree Agree x 1
                    • ir3333
                      ir3333 Well-Known Member
                      4,386
                      994
                      Jun 1, 2008
                      ontario,canada
                      Local Time:
                      8:28 PM
                      i have checked with many body shops and none of them use epoxy primer when painting a car.They say it is a good idea on frames and such. Why epoxy for the body components?
                    • 1969383S
                      4,780
                      1945
                      Jan 8, 2012
                      Cumming, GA.
                      Local Time:
                      9:28 PM
                      Super hard and superior binding to bare metal! You want that bottom level protection! Not a painter, like said but why just on a frame? All the metal needs love!
                    • pishta
                      pishta I know I'm right....
                      15,412
                      5096
                      Oct 13, 2004
                      Tustin, CA
                      Local Time:
                      6:28 PM
                      the 2K epoxy you have to pop the bottom on has compatibility needs: make sure whatever you want to cover with is compatible with your base primer.
                    • Roadart
                      167
                      33
                      Jun 18, 2018
                      Escalon ca.
                      Local Time:
                      6:28 PM
                      Thanks to all for your help. Will get a filter and go from there.
                    • barbee6043
                      11,166
                      3812
                      Jul 20, 2008
                      Local Time:
                      8:28 PM
                      Heck I know a body shops that STILL apply filler over BARE metal instead of Epoxy primer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! WHY!!!!!???????????????????????????????///
