RB 440 Oil Mods [Blocking off top of motor]
Big Block A body Tech
  1. 1Badcolt
    1Badcolt Well-Known Member
    1,737
    690
    Mar 15, 2013
    Georgia
    Local Time:
    5:57 AM
    Someone please educate me with above topic because of using a solid cam . I was told it keeps oil off of top of motor and keeps it downstairs ???
  2. 440dartsport
    440dartsport Well-Known Member
    607
    131
    Oct 14, 2010
    Kewaskum, WI
    Local Time:
    4:57 AM
    I wouldn't block off the oil to the top end. I turn my RB Stroker motor to 7200 rpm consistently with a solid cam. Run a Milodon external oil pick up and full groove main bearings and you'll be good to go.
  3. DartVadar
    DartVadar Well-Known Member
    1,298
    42
    Apr 3, 2013
    Alberta
    Local Time:
    4:57 AM
    Why would you want to limit oil to the top end? Isn't that the last place to get oil anyways.
  4. bOb shingler
    bOb shingler Well-Known Member
    3,250
    163
    Jun 8, 2007
    warrenton, north carolina
    Local Time:
    5:57 AM
    this will work better for you. drill and tap 1/8" set screws in each passage to the heads. seal with loctite. turn #4 cam bearing upside down and drill new hole to feed the main. use full grove mains. this will supply full time oiling to the main and rod on each side. these are the two rods that will spin their bearing when oil supply is low. this will also provide full time oiling to the rocker gear also. now if you think you have too much oil up top tap and install a carb jet of your choice or tap the passage at the deck and install a 1/8" pipe plug with a hole drilled in it the size you need to hold down the oil supply.
    • Like Like x 1
    • moper
      moper FABO Gold Member FABO Gold Member
      15,771
      1887
      Dec 27, 2004
      eastern CT
      Local Time:
      10:57 AM
      The premise is just as Bob's picture above shows - Because the oil is fed down to the mains through the same passage that connects through the camshaft to feed the rockers, the oil going up to the heads can take volume away from the #4 main, which in turn can limit the oil for the rods that main feeds. IMO - you need some really large clearances, a grooved #4 cam journal or grooved bearing, or really high sustained rpm to encounter that issue. What are the plans for this engine? What heads are you running?
    • mguner
      mguner How many is too many?
      5,129
      361
      Nov 26, 2006
      Amarillo,TX
      Local Time:
      4:57 AM
      What about the mods for the roller cam setup where you run a tube down the galley and dimple it for the tappets? Is that no longer needed for the new style lifters?
    • moper
      15,771
      1887
      Dec 27, 2004
      eastern CT
      Local Time:
      10:57 AM
      The new lifters will minimize the pressure leakage but only address that particular problem. Personally - I would have the lifter bores bushed.
