I have a 73 440 block that I am rebuilding. It is stock bore and only needed honed so I am using the stock pistons with new rings and new bearings. The lifters look to be in bad shape and need replaced. Can I re-use the old camshaft? Thanks FABO.
No you can not.I have a 73 440 block that I am rebuilding. It is stock bore and only needed honed so I am using the stock pistons with new rings and new bearings. The lifters look to be in bad shape and need replaced. Can I re-use the old camshaft? Thanks FABO.
THAT he can do... but as for running new lifters on it after the old ones already "look to be in bad shape", nope. Better have a qualified person look that cam over 1st and move from there.He could have the cam re ground.
UTG would call those moderately worn, but maybe good for daily driver
