alsdemon
mains and rods are done now on to oil pump. after checking the pump inside,just read the MELLINGS post.how far do you want to sump off the pad? maybe a little clay on the bottem of the pad to see how close it is? the cam has been run before still break in with cam lube? put the lifters in after i get the heads on that way they done fall out? it,s on a stand.
