General question. If I swap backing plates and hardware will it change diff width. Like going from a 1.75 to 2 or 3 inch drum. I’m trying to change to an easier to get drum. Don’t want rear disk. The front is 11 inch disk. Craig
I believe BUT do not know for fact, the backing plates will have the depth compensation if you were to go from 10 x 1.75 to 10 x 2 etc. so the overall width will not change
Note: there is a spacing difference from bearing to wheel mounting flange from real A body axles vs cut down B,C,E body axles
I understand, I was only pointing out because if you take brakes from a B or E body for instance and put them on an A-body housing with A-body axles there might be a dimensional mismatch due to the axle spacing (wheel mounting flange to bearing #1) As I understand it the A-body axle has a shorter dimension (#1) than the other body axles.Not swapping axles only brake stuff.
