Dodgenut64
What is the standard length of a wheel stud? I need to order wheel studs for my rear axles, the kind that screw in. I see Summit has them. Heres the question, I need them a little longer then stock length, but not crazy long. I plan on using a spacer 1/4 inch thick latter with my 17" rims. I assume that if I get wheel studs 1/4 inch longer then stock it should make up for the spacer right. OK, whats the standard legnth wheel stud on a rear axle? Thanks
