Rear bearings, green vs timken
J-MacsMopars
Shade Tree Vintage Auto on YouTube
Utah
I am sure this has been brought up before. What is the better bearing and why? I am rebuilding a 67 b-body 8 3/4 for my duster which will be daily driven. I drive the car hard and play even harder. I will be running a 741 case with sure grip and currently running factory 10" drum brakes. If it matters, the car has a mild 340 with built 904. I plan to run 15" wheels and SS springs with rear sway bar.
Thanks in advance for the thoughts...
Woodie
Take-off EH!
Ontario
I am in the process of replacing mine as well. After some research, I am convinced the "Green Bearings" are the way to go. No internal seals to worry about and no preload adjustment. Simple easy and affordable. I ordered mine from Mancini $85.00 bucks plus the cost to have them pressed on to the axles by a machine shop.
Bad Sport
HALF A BUBBLE OFF
Staff member
The Wolverine State
You're gonna get varied opinions. Personally I like the tapered roller bearings. I have never used the green bearings, and I don't expect I ever will.
67cudafb
Florida
I am old school and prefer stock timkens my self. May be stuck in my old ways and think they are a lot stronger then green bearings.
Woodie
Take-off EH!
Ontario
if there is any wear on the axles where the "lip seal" rides its going to leak. I took a good look at mine and decided on the "Greens" One can always drift the seal in short in the axle tube to compensate, but for the average Joe... The "Greens" are simple install.
barty005
Auckland New Zealand
I have greens as well easy to fit place in oven ( while wife is out) warm them up bout 170-180 they'll drop right in place on shaft. Considering all modern cars now run seal/green bearing they can't be to bad.
replicaracer43
Grumpy Old Man
Green bearings are simple and easy to install, but they are a Ball bearing, unlike the factory tapered design. I personally do not use green bearings, the tapered kind can last 40+ years with no problems, and I never had issues with oil leaks either.
Woodie
Take-off EH!
Ontario
I'd like to hear if any one has had failure with the Greens... I could not seem to find any negative feedback..?
Bad Sport
HALF A BUBBLE OFF
Staff member
The Wolverine State
There has been a few threads here about the failures. There are also a lot of guys running them without issue.
Ever see an axle walk out of a housing and tear up the rear quarter?
Bad Sport
HALF A BUBBLE OFF
Staff member
The Wolverine State
J-mac, if you do go with the ball bearings, I think the ones with the snap ring are the ones you want if your suregrip has the thrust buttons/block in it. If you use the other version they need to be removed.
Woodie
Take-off EH!
Ontario
Ever seen an axle walk out of a housing and tear up the rear quarter?
Good point. now I have been schooled. That's a scary thought. I would prefer a wet set of Brake shoes any day.
Bad Sport
HALF A BUBBLE OFF
Staff member
The Wolverine State
I'm not saying they are bad, as I said a lot of guys run em with no issues. I just can't bring myself to use them on a street car with a lot of turning involved. I would probably run them on a straight line car just because it would be easier to swap out a center section.
We'll see if Cosgig jumps in here, I believe he knows of a few failures local to him and I.
Woodie
Take-off EH!
Ontario
The insight is appreciated. I had a torn seal on the left axle, the axle is grooved pretty good.
AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
South-Central Manitoba,Canada, 900ftelevation
Perhaps if you swap that grooved axle to the other side it will ride in a better area. Theres no law that says the adjuster has to be on a certain side. Or you can swap the adjuster also at time of pressing.
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
Green bearings get a bad rap because there are two kinds. The first older style was an inferior design and was prone to failure due to excessive side loading. The second later designed is much improved having resolved those issues.
I used to know how to tell them apart by number and name, but I have forgotten. Maybe Supershafts or Dr Diff will chime in. I have seen one or the other....or maybe both talking about the same thing.
The green style bearings have been used on cars and trucks for a very long time and you do not see large scale failures. It's a very good design, you just have to get the right ones.
J-MacsMopars
Utah
I plan to buy from Dr Diff, I just priced all the brake lines out and it's going to get expensive. Lol
67Dart273
Idaho
My old V code 70 RR had the livin' you know what run out of it. The rear bearings lasted nearly 100K as I recall. I'd say if the axle seal surfaces are in good shape stay with tapered. Adjustment is not that hard, and is right in the shop manuals. A tapered roller, all things being equal, has much more side load capacity than a ball bearing of similar size
If you are narrowing a housing I can see that greens might be easier
abodyjoe
Berlin,N.J. 08009
this is a debate that will never die.
all i can say is that the rear in our dart has had a the same set of green bearings in it since the mid 90's and i have never had any issues with them. tons of hard street miles and it was beat to hell at the track. still no problems.
if ya go green then call dr diff and he will sell you the correct ones.
straightlinespeed
Sometimes I pretend to be normal
Uvita, Costa Rica
I've read and read and read.. Lots of opinions on green bearings.. Lots of people saying they fail, but what I have not read is someone that actually running them and theirs failed. Just people saying they fail. Sure there may be pics of them, but what did they do to cause them to fail? Any bearing can fail. There is always a cause. With that said, Im running them and I have not been easy on them, corners, sideways, you name it. I know a lot of drag racers that are using them as well. I say run them!
340Dart
Obsessive Dart Disorder
Mount Morris, New York
I've had the Green bearings on my Dana 60 for 6 years no problems. Got mine from Dr. Diff.
Fred B
d55dave
Kelowna, British Columbia
Here we go again, LOL
Actually, there are seals to worry about with green bearings......they are integral with the bearing, and if they allow the diff lube into the bearing they could possibly lead to a premature failure of the bearing.
Honestly, it takes all of about ten minutes to set up the end play in tapered rollers, the argument the green bearings are easier to install does not fly, at least with me.
My opinion....and only my opinion......if you are a dedicated drag racer and change the pumpkin often to suit different tracks I can see using green bearings.
If it is a street car, stick with tapered rollers. They are simple. They work. The rear end was designed to use them. They last for 40 plus years with a little grease every now and then.
My 2 cents
mderoy340
Melbourne FL
I run the green bearings/snap ring type and still use the inner axle seals. I get them from Dr Diff and never had any failures street and strip driver. I'm also not sure if all Timken bearings are still made in the USA.
