bbab3
- Joined
- Feb 4, 2007
- Messages
- 294
- Reaction score
- 196
I have a brake system that is far from stock. I am using a hydroboost froma Chevy Astro van, an aluminum style Mopar master, A-body drum-drum distribution block, front disc Mopar 11" and Ford Explorer rear disc setup on a 9" rear axle. After bleeding the power steering pump and hydroboost the brakes worked way better than before, with one exception the rear brakes are hanging up. Additionally, it is possible that the rear discs were having this problem before the install of the hydroboost. Any suggestion on where to start since the master does not have a residual valve? Thanks
