May 8, 2015 #1 woodchip Well-Known Member Joined Jan 28, 2010 Messages 107 Reaction score 4 Location Glendale, Arizona I only wanted to change the rear seal! Attachments Rear main bearing.jpg Rear main bearing.jpg 30.2 KB · Views: 381
May 8, 2015 #2 B-onefan Well-Known Member Joined Oct 2, 2009 Messages 1,175 Reaction score 126 Location Texas did you check the thrust bearing also?
May 8, 2015 #3 woodchip Well-Known Member Joined Jan 28, 2010 Messages 107 Reaction score 4 Location Glendale, Arizona B-onefan said: did you check the thrust bearing also? Click to expand... I guess I'll be changing all the bearings....... so much for my thoughts of just doing seals and gaskets. I'm just glad I didn't drive it to Vegas with the leaks. Maybe it should be a stroker when I put it back in! Attachments Rear main bearing2.jpg Rear main bearing2.jpg 32.3 KB · Views: 304
May 8, 2015 #4 krazykuda Well-Known Member How-To Section Editor Joined Aug 20, 2007 Messages 67,760 Reaction score 31,745 Location Orland Park, IL Here's a cheap "refresh" kit to get you started... http://www.manciniracing.com/sealedpowerkit.html More options: http://www.manciniracing.com/enrebkit.html
May 8, 2015 #5 autoxcuda Well-Known Member Joined Apr 6, 2007 Messages 9,519 Reaction score 5,044 Need to find out what (or if something) caused that before you put it back together.
May 8, 2015 #6 GeorgeH Well-Known Member Joined Sep 23, 2014 Messages 8,660 Reaction score 3,608 Location Liberty, NC autoxcuda said: Need to find out what (or if something) caused that before you put it back together. Click to expand... X2 can be a few different causes for that
May 8, 2015 #7 lilcuda Well-Known Member Joined Apr 15, 2006 Messages 1,140 Reaction score 153 GeorgeH said: X2 can be a few different causes for that Click to expand... X3 something is very wrong. Need to find out what.
May 9, 2015 #8 AJ/FormS 68 Formua-S fastback clone 367/A833/GVod/3.55s Joined Jan 19, 2014 Messages 26,608 Reaction score 13,844 Location South-Central Manitoba,Canada, 900ftelevation Is that melted babbet material? With that much babbet squeezed out,the shell should be all copper colored, or worse.
May 9, 2015 #9 woodchip Well-Known Member Joined Jan 28, 2010 Messages 107 Reaction score 4 Location Glendale, Arizona Yeah, I can feel a small grove worn in the crank where that bearing was melting.
May 9, 2015 #10 GeorgeH Well-Known Member Joined Sep 23, 2014 Messages 8,660 Reaction score 3,608 Location Liberty, NC In my case was the converter that did this type of damage.
