mopowers
I've got both types of small block rear main seals sitting on my bench (rubber and viton). Which one do you SB guys prefer? I've only ever used the regular ol' rubber version.
Do you still put a tiny smear of RTV where the ends meet on viton?Viton is more chemical resistant, better than the conventional rubber seal.
If you have it use it.
That sounds like a nightmare. Glad you got it squared away.I have just finished my last attempt at rear main install. Hope yours isn't as troublesome as mine was. It leaked with the Felpro seals, 440 source Viton seals, and the Fastfish one piece seal. I finally got it to seal with the Best seal rope seal. I used a small amount of RTV on the ends of all types except the rope seal. For it I used Permatex Motoseal case sealer on the retainer block and I'm sure it went over the rope seal ends a small amount.
I haven't had the car drive able yet, so don't know how it will finally end up. The Motoseal was a substitute for Yamabond brand case sealer recommended by other users here. Just my 2 cents, Hoping you have much better results than I did. I wish I would of started with the case sealer instead of the Ultra black I was using.
Did you pull the crank to put in the upper seal or did you "sneak" it in with the crank in place?I have just finished my last attempt at rear main install. Hope yours isn't as troublesome as mine was. It leaked with the Felpro seals, 440 source Viton seals, and the Fastfish one piece seal. I finally got it to seal with the Best seal rope seal. I used a small amount of RTV on the ends of all types except the rope seal. For it I used Permatex Motoseal case sealer on the retainer block and I'm sure it went over the rope seal ends a small amount.
360340 or 360 ?
