1. superchargeddrt
    superchargeddrt FABO Gold Member FABO Gold Member
    2,062
    638
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    11:41 PM
    Okay,
    So I pulled the engine back out of the Dart after checking with dye to determine what was leaking. It looked like the oil was leaking from the oil pan gasket in the rear but after changing the gasket and reinstalling the engine I still have a leak! I can't get the oil pan off while it's in the car because the oil pan pickup is not allowing the pan to move forward. My question is is it feasible to loosen the K member while supporting the engine from the top with a hoist to gain the extra space I need? The oil pan is one of the 8 quart Milodons that bell out on the bottom. If any of you have a trick for removing the pan while in the car I'm all ears. This is the most frustrating experience of my life and I'm ready to drop the tools and wait until next year. Thanks for your help.
  2. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    3,241
    2204
    Jun 1, 2016
    breakwater
    Local Time:
    8:41 PM
    I have the same pan, but with the front corner mod and would like to know as well. Gonna attempt this soon or not .
  3. superchargeddrt
    2,062
    638
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    11:41 PM
    Probably next weekend. I will keep you all informed.
  4. inertia
    inertia Well-Known Member
    3,150
    472
    Feb 4, 2011
    Victoria B.C. Canada
    Local Time:
    8:41 PM
    Can you reach thru the gap, undo the pump, let it drop in the pan. ?
    Seems to me I went thru a similar thing, decades ago.
    • Like Like x 1
    • robert flippo
      robert flippo Well-Known Member
      147
      93
      May 9, 2018
      gibson station va
      Local Time:
      11:41 PM
      with large oil pan may take motor mounts loose and raise the motor enough
    • superchargeddrt
      2,062
      638
      Aug 24, 2009
      Pittsburgh, Pa.
      Local Time:
      11:41 PM
      Q
      Good idea! I think we might try that. Thanks!
    • pishta
      pishta I know I'm right....
      14,245
      3914
      Oct 13, 2004
      Tustin, CA
      Local Time:
      8:41 PM
      even the stock 65 pan takes the right crank clocking to get the pan off with the motor in the car. Have you tried turning the crank or is it obvious that the pickup and pan shape prevents an easy slide out? Trouble with the engine hoist is that your back under the car with the motor slung and that is dangerous. Pick the motor up and wedge a 2X4 block under the motor mount for some physical support. Watch the distributor and the fan when you pick the motor up.
      • Agree Agree x 1
      • superchargeddrt
        2,062
        638
        Aug 24, 2009
        Pittsburgh, Pa.
        Local Time:
        11:41 PM
        I forgot that I have a windage tray and I can't get to the oil pump bolts ARRRRRRGH
      • sireland67
        sireland67 Well-Known Member
        7,945
        1993
        Oct 27, 2010
        WV
        Local Time:
        11:41 PM
        Just pull the motor.
        I bet you could have already had the engine out with as much time you have spent trying to take a short cut.
        • Agree Agree x 4
        • diymirage
          diymirage HP@idle > hondaHP@redline
          15,172
          7593
          Oct 12, 2012
          michigan
          Local Time:
          11:41 PM
          Ever since you took that blower of its been nothing but problems, hasn't it?
        • superchargeddrt
          2,062
          638
          Aug 24, 2009
          Pittsburgh, Pa.
          Local Time:
          11:41 PM
          Hate to say it but it sure seems that way.
        • diymirage
          15,172
          7593
          Oct 12, 2012
          michigan
          Local Time:
          11:41 PM
          Kinda reminds me of my bronco...nothing but problems
        • Wyrmrider
          Wyrmrider Well-Known Member
          1,233
          455
          Sep 5, 2016
          los angeles
          Local Time:
          8:41 PM
          here's the last picture of the rear main seal b 4 it was eaten by a great white
          • Like Like x 5
          • superchargeddrt
            2,062
            638
            Aug 24, 2009
            Pittsburgh, Pa.
            Local Time:
            11:41 PM
            Yeah I agree but I'm having trouble getting up the ambition to pull it out after just putting it back in a week ago.
          • sireland67
            7,945
            1993
            Oct 27, 2010
            WV
            Local Time:
            11:41 PM
            At least the bolts will come out easy.
            • Like Like x 1
            • yellow rose
              yellow rose Doctor of Thinkology.
              16,097
              12529
              Jun 19, 2015
              Living on the razors edge
              Local Time:
              8:41 PM
              Yep, you're stuck. I couldn't get a stock pan off in the car and I fought it like jack the bear (I was substantially younger back then) until I had enough and just pulled the engine.
              It's hard to get motivated to do the work over but it's actually quicker and easier to yank the pig out and fix it.
              BTW, when you check the rear main seal, look very close at how far the seal is proud from the cap and block.
              You really only need .010-.015 crush on the seal and that's plenty. I never clock the seal with the ends below the cap and block.
              If your block was line honed it makes the seal stick too far out of the block and cap. When you bolt them together with too much crush, it will force the seal out of round. And it will leak.
              The only fix I know is to very carefully sand a little off both ends of each seal until you have the correct amount of seal sticking past the cap and block.
              Practice up on the old seal before you work on the new seal. I just use a little belt sander. Keep the ends as square as you can.
              That's my best .02 cents to try and help you. You'd be surprised how many guys don't check that and end up with oil leaks at the seal.
              That and putting either the whole seal in backwards. Or just on half of it.
              Don't ask how I know that. Just know that I know it.
              • Like Like x 4
              • AJ/FormS
                AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
                15,653
                4650
                Jan 19, 2014
                South-Central Manitoba,Canada, 900ftelevation
                Local Time:
                10:41 PM
                Hyup, I got caught on that line-hone thing. The shop basically Junked my block. After replacing the seal once and having it leak again before the end of the summer, I went back and looked at the first seal, and don't you know it, the evidence was right there. But it was so bad I went back to the machine shop, and showed them. With a straight face the guy behind the counter said "Bring us another block and we'll fix it; no charge." What about the decking and boring and squaring? "Well, no; we didn't do any of that machining".
                And they never will see me again.
                Ok long story short, I got a rope seal from a 383 and stuffed it in there with a little trimming. It's not happy about the knurling back there, but it's tolerable.
                • Thanks! Thanks! x 1
                • Wyrmrider
                  1,233
                  455
                  Sep 5, 2016
                  los angeles
                  Local Time:
                  8:41 PM
                  good advice YR
                • yellow rose
                  16,097
                  12529
                  Jun 19, 2015
                  Local Time:
                  8:41 PM
                  If you do a rope seal correctly, they actually work well.
                  • Agree Agree x 1
                  • superchargeddrt
                    2,062
                    638
                    Aug 24, 2009
                    Pittsburgh, Pa.
                    Local Time:
                    11:41 PM
                    Thanks for all of your advice guys. I guess we are pulling the engine a second time. This is what I get for not changing that seal as a matter of course. I am gonna give it one more try this year and if it still leaks it's gonna wait until next season. Thanks Again!
                    • Like Like x 1
                    • AJ/FormS
                      15,653
                      4650
                      Jan 19, 2014
                      Local Time:
                      10:41 PM
                      Ok truth? It took me a couple of tries,lol,
                      But in those days I was taking the 367 out every September long, and swapping in my 318 test mule engine for the winter. So then I would take the 367 apart over the winter looking for issues before they spoiled my next summer. The engine usually went back in on May-long. Most of the gaskets were the re-useable type, so this wasn't costing much more than time.
                      The first rope seal was a disaster; it did not survive the install. The second didn't pass the pressure test. The third time was a charm. Fourth and fifth,also good. Now it's been in there since 2004/5.
                    • AJ/FormS
                      15,653
                      4650
                      Jan 19, 2014
                      Local Time:
                      10:41 PM
                      Rig up a pressure test while the engine is still on the stand. I use 3 to 4psi NO-MORE, else it will want to blow something out. Please Lord don't let it be the rear cam plug.
                      4 psi doesn't sound like much, but on a 2 inch round plug that is 12.5 pounds of force. Can your cam-plug take it? Let's find out, shall we,lol.
                      Your engine normally is ventilated so should never generate 3 to 4 psi pressure. At least not in it's early years,lol. But pressures that low are really hard to regulate. I shoot for 3 and panic at 4.Once the pressure stabilizes, I hit it with the soapy water trick.
                      May the force be on your side.
                    • jdsduster
                      jdsduster Well-Known Member
                      1,075
                      107
                      Aug 5, 2011
                      indiana
                      Local Time:
                      11:41 PM
                      this has got to be very frustrating,i feel your aggravation .
                    • nm9stheham
                      nm9stheham Well-Known Member
                      10,562
                      2778
                      Dec 20, 2013
                      Waynesboro, VA
                      Local Time:
                      11:41 PM
                      The IF is the issue... I am about 50-50 with rope seals ... I guess that is better than 0-100, but I suspect a child could do better LOL
                      The only rear seals I have had 100% success with are the full circular seals in some other engines.
                    • yellow rose
                      16,097
                      12529
                      Jun 19, 2015
                      Local Time:
                      8:41 PM
                      That's because the full circular (one piece) seals aren't affected by line honing.
                      50/50 isn't bad. I know guys who are O'fer on them and won't even look at them.
