superchargeddrt
Well the good thing is that my engine builder checked my block and told me I could save $75.00 as it didn't need line honing, so we should be good there.
Well the good thing is that my engine builder gecked my block and told me I could save $75.00 as it didn't need line honing, so we should be good there.
Here ya go....I need the special tool to install those one piece seals on my mopar
Wow, that's really cool of you. I will let you know, thanks again!Glen,
I have an engine start stand I built for a small block mopar.
When I built it, it was a stand alone system with radiator, electric fan, full gauges, charge system, start system and run.
You are more welcome to borrow it, but I robbed about everything except a set of motor mounts, bellhousing and neautral balance flywheel. You would have to add your own wiring, cooling, gauges etc.
Its basically just a square tubing frame on casters, with the mounts for everything.
That would allow you to check everything before putting it back in the car.
HELP!!!! ....LOLPretty damn nice of you sireland. Love to see one FABO member helping another.
THANK YOU
THANK YOU
HOOK ME UP!!!!Its nothing, he hooked me up with his old supercharger off his car.
Thanks Mike,Holy crap Glenn! Wondered where the he'll you've been......Sorry about all the problems, but we've all been there buddy.
How did the leak start after all those dyno pulls?
If you haven't bought one yet, call Rick at Superformance. He MIGHT have a couple of his pink ones left. By far the best rear main seal I have ever used. Never saw one leak, if installed properly.
If you need any help call me anytime!
Thanks Mike,
Larry and I are working on it on Saturday if you're interested in stopping by. I will text you my address. I already have a seal but if you think that the Superformance seal is that muck superior then I have no problem ordering one.
Well I talked with Greg at Suerformance today, really nice guy, we talked for about 15 minutes and I did order one of his main deals. I will let everyone know how it works out.Pretty much everything Superformance makes is top notch and worth the money.
i recently opened up my 72 340, PO had bent back corner of windage tray to get at bolt,wasnt pretty but i guess it worked for him, i just bent it back into place.just a thoughtI forgot that I have a windage tray and I can't get to the oil pump bolts ARRRRRRGH
Thanks Mike,Well this is probably gonna cause a controversy. Here goes:
Glenn, make sure you "clock" the seal so about a quarter inch is out of the block on one end and the cap on the other side. A tiny tiny bit of silicone on the end surface.
In other words, you don't want the seal joint to be right at the cap/block joint. That opens the door for a leak. Learned this from a Jedi Master about 40 years ago........
I have NEVER put an engine together with a rear main leak, weep, drip, or otherwise. Helluva lot of other crap but.......Well you know....
That's exactly what I meant. I use Ultra Gray myself, but either way just a very thin coat on the ends only.Thanks Mike,
I had a lengthy conversation with Greg. He says if I am going to clock the seal to not go more than 3/8". GE also said NO SILCONE on the seal except for a small amount of Ultra Black on the separate end pieces. I am going to be working in the garage tomorrow if you want to join us.
The "helical" markings toward oil, right? It's easy to get Greg's in backwards....Okay,
So here's the update. Larry and I got the engine out of the car yesterday. We remove the oil pan, windage tray, oil pump and main bearing cap. The seal looked like it was installed correctly with the larger end facing towards the front of the engine and it appears to be in good shape. We removed the old seal, meticulously cleaned the main bearing cap and installed the new seal from Superformance. Everything is back together now and engine is ready to go back into the car. I am going to remove the distributor and prime with a drill to look for a leak before I install it back into the car. I will let you guys know what happens.
