Rear parking brake cables?
coalman
Texas
I am making progress on installing the brake cables. There are left and right mounting plates with two holes in them near where the left and right rear brake cables come out of the drums, this is where the exhaust pipes are mounted. Do any of you know if that are where the rear parking brake cables are suppose to go, and does it matter in what holes, one up, one down, 1966 Dart??? Thanks a bunch....
They only go on one way, one side...
The holes for the parking brake cable go towards the front of the car on the bottom of the backing plate. You should be able to reason out which side goes where from there...
Do you have the equal length rear cables or the different length ones, it affects the routing forward of the axle...
Equal, sorry about these stupid questions, but the whole parking brake system was basically gone.. Thanks again
This is what you should have. I have a comlete setup for sale in the "ForSale" section
