They had a version for automatics and another for stick applications, but I don't know which these are. However, even the stiffer stick application version was marginal for use with current high stall converter technology. Probably stiffer that OEM for street use. Not sure if the old, original bushings could be swapped out without damaging the replacements. Ideal material would be the firmer polyurethane material. But it would have to be a 2 piece because it certainly wouldn't be flexible enough to force through the ends.
