rear sump oil pan for slant six
HemiDenny
HDK Suspension
NW Ohio
looking for a picture....or source for a rear sump oil pan for a 225 / 6cyl.
Thanks,
Denny
Here's a picture. The one in the upper right hand corner is the truck pan.
You may want to try Dorman. I needed a 318 truck pan and got it from Summit replacement parts.It was a Dorman part. Maybe?
Negative. I've been looking almost all morning. Nobody makes one anymore. Used will be his only choice and I have not found one of those either.
Denny, Try the guys over on slantsix.org One guy from Maryland races a Slant pickup.
His name is Rick Covalt.
I can get you a photo of the one in my truck, it's an 82 D-150 with a slant. It will be a little later today when I get out to the shop.
Here are the shots of the pan on my 82 D-150. They are a little less than crystal clear due to it still being in the truck. It's coming out for a timing chain and other upgrades in the next day or two, if you need something else let me know.
Here ya go, pix of the pan now that the engine is out. If you still need a pan try Wildcat Auto Wrecking in Sandy, OR. They have a tremendous stock of all things Mopar.
I just got a truck pan, no it isnt for sale (I need it for the "new and improved" engine I'm working on for my truck) wasn't hard at all to find.
now to go and jab the machine shop so he gets going on my engine that has only been there what... 5 months now? the only thing I have asked for so far, is a measure out so I know what O/S parts are gonna be needed...... cant even get that done.... there was a Q about possible crack in outside water jacket, he sent it out for shot peen and "more complete" magnaflux than what he has...... came back with clean bill of health... good news since I got this engine in pieces.... and all weren't there.
need to flip a coin and decide which of the 2 cams that I want mine ground into being...... and get it out to Oregon to be done. debating between their 819 and the Dutra RV10/15 RDP
As much as yall fab stuff, Make one. Shouldn't be that bad.
I would like one for the HDK rack / coil-over / 6cyl mock up....No problem to fabricate / modify a pan, but prefer off the shelf components work with the package.
I will likely get one from car-part.com.....thanks Charrlie_S
