[FOR SALE] Rebuilt 413 & Trans
gtsjohn
Ohio
1973 Rebuilt 413 block 030 over forged piston, forged steel crank ,reconditioned stock rods, balanced rotating assembly, Aluminum stealth heads, Aluminum water pump housing, 7 quart Milodon oil pan, Hughes 490 cam, New 770 Holley street avenger carb. Edelbrock RRM Intake,Electronic distributor, Motor Complete with rebuilt 727 with shift kit, Hughes 2500 converter, Motor & Trans.has 130 miles on them, Still in car at this time can hear run, 70 Lbs oil pressure when hot at idle. Being sold Carb to Pan with Trans.$4,950.
Is that one of the motor home/truck/industrial based engine blocks? Care to show a pic of the front I.D. pad stamping?
1973 Rebuilt 413 block 030 over forged piston, forged steel crank ,reconditioned stock rods, balanced rotating assembly, Aluminum stealth heads, Aluminum water pump housing, 7 quart Milodon oil pan, Hughes 490 cam, New 770 Holley street avenger carb. Edelbrock RRM Intake,Electronic distributor, Motor Complete with rebuilt 727 with shift kit, Hughes 2500 converter, Motor & Trans.has 130 miles on them, Still in car at this time can hear run, 70 Lbs oil pressure when hot at idle. Being sold Carb to Pan with Trans.$4,550. SOLD
