Rebuilt 727 slow to no engage
Transmission and Drivetrain Tech
  1. my5thmopar
    my5thmopar Life Long MOPAR Owner FABO Gold Member
    940
    197
    Jul 15, 2011
    Tennessee
    Local Time:
    11:43 PM
    This is in my D100-440 project. The trans is 1966 and was rebuilt by shop not, me. The guy I got it from has used the shop before and says they do good work but, who knows. Yes I know, go ahead with the tongue lashing. I should have pulled the pan and checked their work. I added a Lokar kickdown cable and shifter which meant I had to loosen the forward/kickdown band nut. (not the adjuster). It was at 2.5 and I did adjust it per the FSM. The engine has to be revved 3k to get engaged in any gear. Sometimes after it engages, it shifts normal between all P-R-D gears at idle. Note: I have not road tested yet. The TC was used and came with the trans. I believe it is stock and big like 11/12 inch. The fluid level is correct and the dip stick measured with the case. Any quick suggestions before I pull trans or the pan and start looking? Also, what are symptoms of a bad TC? Thanks Craig
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    11,143
    1681
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:43 PM
    I would ask the guy u got it from to return for them to look at. Kim
    • Agree Agree x 1
    • my5thmopar
      940
      197
      Jul 15, 2011
      Tennessee
      Local Time:
      11:43 PM
      Sometimes things change and you don’t have that option. I’ll have to figure it out myself.
    • CudaFactHackJob
      CudaFactHackJob Well-Known Member
      508
      152
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      11:43 PM
      Dump another quart in it. Are you checking BOTH sides of the stick in neutral?
    • my5thmopar
      940
      197
      Jul 15, 2011
      Tennessee
      Local Time:
      11:43 PM
      Yes and yes. I understand it acts like it is low but it’s not.
    • Demonic
      Demonic Well-Known Member
      483
      272
      Mar 21, 2015
      Maryland
      Local Time:
      12:43 AM
      Buy a large diameter 300 psi pressure gauge, a few 1/8" npt fittings, and some hose. Pressure tests are easy to do with a FSM or one of the books by Munroe or Tom Hand.
    • VOETOM
      VOETOM Well-Known Member
      825
      270
      Jul 27, 2008
      KC, MO area
      Local Time:
      11:43 PM
      Summit has a pressure gauge and hose for $69 now and it'll help you diagnose issues like this.
      Tom Hand
      • Thanks! Thanks! x 1
      • CudaFactHackJob
        508
        152
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        11:43 PM
        Maybe your converter valve is backwards. The one right next to the pressure regulator valve.
      • my5thmopar
        940
        197
        Jul 15, 2011
        Tennessee
        Local Time:
        11:43 PM
        Update. Trans guy says it’s the converter but, I don’t buy that. Read on. Road tested today. Checked fluid and slightly over filled now. Revving heavy, engine in neutral, I hear the pump whining and it engages. I have a 2-3 flare and very delayed KD. I’ve readjusted the KD band and cable. KD at 2 turns and cable probably a little loose. I’m disappointed since this was rebuilt by a ”mopar trans guy” but, something is not right. Suggestions before I order a gage and check pressures? Craig
      • CudaFactHackJob
        508
        152
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        11:43 PM
        I've never checked trans pressures. But you didn't even check the converter valve did you. Are you sure it's full running in neutral and checking both sides of the stick after wiping it off?
      • my5thmopar
        940
        197
        Jul 15, 2011
        Tennessee
        Local Time:
        11:43 PM
        Nope haven’t taken it apart. I’ve been working and driving Mopars since the 70s. You have already asked about the fluid 2x. Same answer not low. I’ve rebuilt AT before and it looks like I’ll be tearing this one down too. Was hopeful for a quick fix but, if you want it done right then you have to do it yourself.
        • Like Like x 1
        • CudaFactHackJob
          508
          152
          Mar 17, 2016
          Hemet, Ca.
          Local Time:
          11:43 PM
          Before you take the trans out; DUMP ANOTHER QUART IN IT. (OR TWO) Couldn't hoight.
        • Tims 66 Cuda
          Tims 66 Cuda Mopar mid life crisis
          89
          19
          May 28, 2018
          Poquoson, Va
          Local Time:
          12:43 AM
          Try adjusting the bands 1/4 turn less than the FSM perscribes. Ive found it to work better and no further adjustment down the road. My .02
          Tim
        • fishy68
          fishy68 Tyr Fryr's Inc. FABO Gold Member
          16,795
          797
          Jan 11, 2005
          Central, IL (Hooterville)
          Local Time:
          11:43 PM
          If it doesn't engage into both forward and reverse it's possible something is put together wrong in the valve body. The only problem is you have already revved it to the moon and back trying to get it to engage and that most likely smoked the clutch packs so i'd take it out for a complete inspection. Your only saving grace for the clutches is it could be a broken torque converter. Was this a working trans/converter when sent to the shop for a rebuild? If it was you can most likely rule out the converter
        • my5thmopar
          940
          197
          Jul 15, 2011
          Tennessee
          Local Time:
          11:43 PM
          Thanks everybody for the help. Update. Although the fluid level is correct, I dumped another quart+ and has over 10 quarts in it now. No change to the issues. After it engages it will shift back and forth through all gears at idle. These trucks have a removal cover and I can clearly hear the pump when it is working. When accelerating normally, the 1-2 is firm (like a TF2 installed but, doesn't have one). The 2-3 flares every time and slips like it was thrown into neutral. Let off the gas and it moves to 3rd and operates normally while in 3rd. KD or quick acceleration causes the same thrown into neutral sound. Fishy, IDK the condition of the TC. If the TC was broken would it exhibit the stated symptoms, make noise, shake etc? Also, doesn't the 66 have a 19 spline TC?
        • Rmoore
          Rmoore Well-Known Member
          236
          110
          Nov 14, 2018
          Gun Barrel City, Texas
          Local Time:
          11:43 PM
          The filter maybe lose. I would sure check that.
        • fishy68
          16,795
          797
          Jan 11, 2005
          Local Time:
          11:43 PM
          I overlooked you saying it does sometimes move. In that case I doubt it's anything to do with the converter. Yes a 66 is 19 spline. How is reverse? Does it act the same as forward?
        • my5thmopar
          940
          197
          Jul 15, 2011
          Tennessee
          Local Time:
          11:43 PM
          Yes once it engages, I can go F/R and have driven several miles but, has the 2-3 issues. Yes meaning slow to engage.
        • KickDown
          KickDown Just a Brit in Germany
          292
          126
          May 22, 2014
          Gifhorn, Germany
          Local Time:
          6:43 AM
          If you have a constant 2 - 3 flare, one of the two steel sealing rings for the reverse/high clutch on the reaction shaft may have been damaged unnoticed while refitting the pump. This is very easily done on an early 727 due to the narrow reverse/high clutch drum bushing which doesn't provide much of a guide while dropping the pump in. A broken sealing ring here would manifest itself by a loud hiss during the air pressure test if one was carried out before installing the valve body.
        • justinp61
          justinp61 Well-Known Member
          1,221
          516
          May 15, 2009
          Local Time:
          11:43 PM
          Do you have a good valve body you can put in it? The 2-3 flare could be the adjustment on the Lokar KD cable.
          Hopefully you haven't smoked anything.
        • oldkimmer
          11,143
          1681
          Nov 11, 2006
          Local Time:
          11:43 PM
          Have u did a pressure test yet? If u can hear the pump TRyING to work u got problems. Low pressure problems. Pump or sealing rings or seals. Kim
        • my5thmopar
          940
          197
          Jul 15, 2011
          Tennessee
          Local Time:
          11:43 PM
          Not yet I’m going to order a gage as suggested.
        • CudaFactHackJob
          508
          152
          Mar 17, 2016
          Hemet, Ca.
          Local Time:
          11:43 PM
          Pressure testing won't tell you if the converter relief valve is installed backwards.
        • my5thmopar
          940
          197
          Jul 15, 2011
          Tennessee
          Local Time:
          11:43 PM
          I visited my buddy today. He gave me the 1976 transmission that came with the 440. The combo was from a running driving truck he owns. I'm going to pull the pan and inspect this one. Although returning the 727 wasn't and option at first, my buddy spoke to the builder. He is returning the it to the builder. Thanks for all the help. Craig
          • Like Like x 1
