scooby67
360 block, new cam bearings and freeze plugs. Stock crank, reconditioned rods, moly rings, tri metal bearings. Keith Black KB107 hypereutectic pistons, High volume oil pump.
Edelbrock Performer RPM aluminum cylinder heads (#60779), 63 cc chambers, stock roller and push rod setup. Edelbrock Performer dual plane intake, Comp Cams hydraulic .525 lift, 275/287 duration cam. Double roller timing set, balancer, water pump, electronic distributor, Rear sump oil pan installed. A center sump is included.
10.5:1 compression ratio, 410 hp with 420 lb/ft torque.
Rebuilt 727 Torqueflite transmission with 2500 stall converter.
Waterbury, CT
$4500 Joe
Waterbury, CT
$4500 Joe
