Recommended fuel pump?
Fuel and Air Systems
  1. phaelax
    phaelax Well-Known Member
    372
    118
    Sep 3, 2014
    Ohio
    Local Time:
    10:21 PM
    Turns out there's a lot more options out there to choose from than I thought, ranging anywhere from $25 up to $200! I have a mildly built 440. Is it best to just stick to mechanical? I think my line is 3/8 but I'll have to double check.
  2. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    81,511
    61120
    Jun 7, 2010
    Georgia
    Local Time:
    10:21 PM
    The Carter Strip pump is an excellent choice.
    • Like Like x 1
    • Agree Agree x 1
    • phaelax
      372
      118
      Sep 3, 2014
      Ohio
      Local Time:
      10:21 PM
      With so many options, I just didn't want to end up with something having poor reliability like most modern products. (voltage regulators come to mind)
    • toolmanmike
      toolmanmike Moderator Staff Member FABO Gold Member
      63,513
      53625
      Jan 18, 2006
      Iowa
      Local Time:
      9:21 PM
      A issue many have been having with new pumps regardless of brand is excessive fuel pressure. Depending on what the pump puts out and what carb you are running will tell you if you need a regulator. Carter/Edelbrock carbs like no more than 5#. Holley's can stand up to around 7#. You should test the new pump to make sure.
    • phaelax
      372
      118
      Sep 3, 2014
      Ohio
      Local Time:
      10:21 PM
      I'm currently using a Quickfuel 750. According to their website, they recommend 6.5 psi with a max of 7. The carter strip states 6.9 to 9.5, so that may not be a great choice. (without a regulator
      • Agree Agree x 1
      • Bewy
        Bewy Well-Known Member
        1,525
        977
        Jan 1, 2021
        Australia
        Local Time:
        2:21 PM
        If the car is not driven often, an electric pump [ Carter ] is a good idea. No need to crank engine to fill the carb as you would have to do with a mech pump.
        The Carter 4594 would be perfect for a mild 440. Cheap & reliable.
        • Agree Agree x 1
        • Disagree Disagree x 1
        • RustyRatRod
          81,511
          61120
          Jun 7, 2010
          Georgia
          Local Time:
          10:21 PM
          A regulator is part of a GOOD HP fuel system and with today's fuels, a return system should be, too. Either you want a good fuel system, or not. Even a "mildly built" 440 is going to have a thirst for fuel over that of a stock engine. It needs a good pump. I normally run high pressure pumps with all of my hot builds, but this slant six is an exception, because no one makes an HP pump for it. But I plan on modifying a Carter strip pump for a big block, adding a return style regulator and a return line to the tank. It's really the only way to feed a real HP build. While you don't have to have a return and you can run a low pressure pump and dead head it at the carburetor, with today's crappy gas, a good return really helps and an HP pump is really the only way to support that. Good luck with whatever you decide.
        • Johnny Dart
          Johnny Dart Well-Known Member
          8,352
          3220
          Nov 30, 2006
          So Cal
          Local Time:
          7:21 PM
          Check out the Carter M6903.
          Reportedly 5.5-6.5 fuel pressure rating.
          No regulator necessary, Carter quality.
          • Agree Agree x 3
          • 383Scampman
            383Scampman Well-Known Member
            1,824
            1026
            Nov 24, 2013
            New Hampshire
            Local Time:
            10:21 PM
            I went through this with my build . I even went so far as to purchase a Carter , Holley , NAPA and Edelbrock . All of them had either 1/4" or 5/16 inlet and outlet except for the Edelbrock which had 3/8" in/out . So that's what Im' using .
          • toolmanmike
            63,513
            53625
            Jan 18, 2006
            Iowa
            Local Time:
            9:21 PM
            Edelbrock recommends no more than 6# and says set your regulator at 5.5. As long as that's what the pump put out you are golden. Always check it though.
          • Mattax
            Mattax Just the facts, ma'am FABO Gold Member
            13,083
            8755
            Feb 7, 2013
            Phila. Pa
            Local Time:
            10:21 PM
            At one time Ryan Brown would test fuel pumps for max pressure and for flow at 4.5 psi resistance through the entire rpm range of interest.
            I'm not sure he still does that since the accident but he's only an email or phone call away.
          • Daves69
            Daves69 Well-Known Member
            6,107
            4685
            Feb 20, 2011
            WestOfChi
            Local Time:
            9:21 PM
            • Like Like x 1
            • lilfontleroy
              lilfontleroy annoyinglilLeroy
              4,340
              3632
              Nov 20, 2017
              Intercourse
              Local Time:
              9:21 PM
              it's simple Simon, get a good pump and use a regulator
              a Holley "red" or "blue" will do the trick for you as will the Carter or any pump that can produce 7+ psi, correct size AN fittings and a fuel pressure regulator (I prefer one with a gauge port), your carb feed line should have a gauge after the regulator and be as close to the carb as possible
              fuel line hard 90's and long runs after the regulator can rob some pressure as will mismatched line ID's, a liquid filled gauge mounted close to the carb will likely get hot and misread after a while, you'll get a good reading from it for long enough to get the pressure set, as long as the reading at the regulator stays set you should be good
              FYI, there's a shit-ton of good reading out there and an amazing array of ways to get this done, your wallet may be the deciding factor. IIRC the "old school" hot rod method is tank, filter, pump, filter, regulator, carb. You should also read up on return lines, they are not always required.
              Good luck with it
            • jbc426
              jbc426 Well-Known Member
              2,066
              886
              May 30, 2007
              West Coast
              Local Time:
              7:21 PM
              Which ever pump you decide to go with, add a return line to your fuel system, so you don't have a deadhead style set-up.
              It's not difficult to do and doesn't cost a lot, but it helps keep your fuel cooler, helps defeat vapor lock and is easier on the pump. You can feed it using either a return style regulator or a 3 nipple fuel filter up near the carb. Be sure to keep your lines away from the hot engine parts.
              I added a larger return line on my sending unit using real silver solder, not the fake kind they sell at many hardware stores. I sourced it from a welding supply house. I used an electric pump, but you can use a mechanical pump with the same style return line. The 1/4" return line is pretty small. I went 3/8".
              • Like Like x 1
              • Scamp Rhonda
                Scamp Rhonda Well-Known Member
                851
                797
                Jan 18, 2017
                Blaine MN and sometimes Florida
                Local Time:
                9:21 PM
                What are your intentions with this build?
                10 second cars run mechanical pumps. Extra or different stuff isn't always necessary in my opinion.
                • Agree Agree x 2
                • Mattax
                  13,083
                  8755
                  Feb 7, 2013
                  Phila. Pa
                  Local Time:
                  10:21 PM
                  Hell I've driven around town on gravity feed. LOL
                  • Like Like x 2
                  • phaelax
                    372
                    118
                    Sep 3, 2014
                    Ohio
                    Local Time:
                    10:21 PM
                    I got my pump from summit last night, put it in this morning. Should've only take a few minutes, but I ended up driving to 4 different stores before I could find the correct connectors. The old pump only had one connector on it and I nearly stripped it trying to get it off. The inlet on it was part of the housing. The old pump appeared to have no way to actually take it apart (I wanted to see the diaphragm) nor any labels or markings to note brand or in/out flow. Trying to keep the pushrod up so I could fit the new pump was an annoyance. Checked for leaks and off I went. I can finally drive my car again! And just a correction to my original post, my hose is 5/16", not 3/8.
                    Carter M6903 Carter Street Super Mechanical Fuel Pumps | Summit Racing
                    • Like Like x 1
                    • Daves69
                      6,107
                      4685
                      Feb 20, 2011
                      WestOfChi
                      Local Time:
                      9:21 PM
                      A dab of grease can help hold the pushrod rod up while you position the pump.
                      • Agree Agree x 1
