[SOLD] Reconditioned 340 forged steel crank shaft
Bigboy 68
it is what it is
Legendary Member
Middletown, Delaware
Rating - 85.7%
24   4   0
Reconditioned 340 forged steel crank shaft 10 on the rods 10 on the mains Thrust is standard asking 475+ shipping
What is meant by "thrush is standard" if the mains are at .010?
Correct.
Thrust is always std unless it ate the bearing through to the block. That's a nice $250.00-300.00 crankshaft. New ones are around $375-600 depending on material, of which most nodular lower cost versions are rated higher strength than the 1053 factory steel cranks.
It does have the 4 spd pilot?
It doesn’t have the pilot bushing but it is drilled for a four-speed I have $425 in it I would like to get that back out of it if I could it’s a really nice crankshaft
