Reinstalling torsion bars on a 67 cuda
Suspension, Steering and Chassis
  1. 273 ball
    273 ball Well-Known Member
    607
    43
    Mar 12, 2016
    hemet
    Local Time:
    11:24 PM
    Hi I do I have back out the adjuster bolt on the lower control arm to put the bar back in
  2. Hyper_pak
    Hyper_pak Old School Chrysler Fan
    3,325
    2693
    Feb 14, 2010
    Desoto Texas
    Local Time:
    1:24 AM
    not sure how you got it out, but yes the adjuster needs to be all the way out, loose. Don't force it, make sure it's all clean and no junk in the hex socket, trans cross member also.
  3. Jim Lusk
    Jim Lusk Well-Known Member
    4,859
    1186
    Mar 8, 2006
    Fresno, CA
    Local Time:
    11:24 PM
    Don't forget to grease both ends of the bar...
  4. MRGTX
    MRGTX Well-Known Member
    1,904
    740
    Sep 24, 2007
    CT, USA
    Local Time:
    1:24 AM
    Jim,
    How much grease are we talking here? I suspect that anything more than a film of grease could cause fitment problems.
  5. UDUST81
    UDUST81 Well-Known Member
    469
    172
    Jan 5, 2014
    Des Moines IA
    Local Time:
    1:24 AM
    any excess grease will squeeze out not a big deal just put on a reasonable amount and youll be fine
  6. RedFish
    RedFish Well-Known Member
    24,947
    3326
    Sep 5, 2007
    Local Time:
    1:24 AM
    When going back, Make sure that the ball end of the adjust screw seats properly in the little pocket of adjust finger. We've seen at least 1 here that missed that target. Ruined the adjust finger.
  7. MRGTX
    1,904
    740
    Sep 24, 2007
    CT, USA
    Local Time:
    1:24 AM
    I'm not convinced that this is right. These are very tight tolerances (on some cars more than others, possibly) and without a vent on the other side, you could have yourself a bit of an air seal happening. I don't believe they're greased from the factory (on the LCA side) and I think there's a reason for that.
    The QA1 LCAs have spaces at the points of the hex (IIRC) on the torsion bar socket...unless someone knows different, I suspect that these might be there to vent extra grease.
  8. JBurch
    JBurch FABO Gold Member FABO Gold Member
    1,915
    1072
    Oct 17, 2009
    Owego, NY
    Local Time:
    2:24 AM
    Yes, what makes you think you do not have to?
  9. MRGTX
    1,904
    740
    Sep 24, 2007
    CT, USA
    Local Time:
    1:24 AM
    I suspect that the OP has yet to start the job and he/she is hoping to preserve the ride height, to avoid having to do a complete alignment possibly?
  10. JBurch
    1,915
    1072
    Oct 17, 2009
    Owego, NY
    Local Time:
    2:24 AM
    OK.........if that is the case, measure ride height before disassembly......though I'm not sure how they would reassemble the car not relaxing the tension........that kind of wrestling knocks cars off jack stands
    • Agree Agree x 1
    • Jim Lusk
      4,859
      1186
      Mar 8, 2006
      Fresno, CA
      Local Time:
      11:24 PM
      They were greased from the factory. I usually take a couple of fingers in the grease and wipe the inside of the socket. There's plenty of room in front of the bar that you'll never have a problem getting the bars in if some grease gets trapped in the front.
      • Thanks! Thanks! x 1
      • MRGTX
        1,904
        740
        Sep 24, 2007
        CT, USA
        Local Time:
        1:24 AM
        Not doubting you here but my factory installed torsion bars came out the the LCAs as clean as a whistle.
      • JBurch
        1,915
        1072
        Oct 17, 2009
        Owego, NY
        Local Time:
        2:24 AM
        Agree, all the ones I've taken apart ( 5-6 ) all had real thick heavy grease on them...........to get back to the original question.......YES, loosen the adjusters for reassembly; get a ride height measurement BEFORE dissembly
        Good luck!
      • 1969383S
        1969383S FABO Gold Member FABO Gold Member
        6,098
        3032
        Jan 8, 2012
        Cumming, GA.
        Local Time:
        2:24 AM
        Heat your boots up in a pot of hot water first as well. The slip on easy that way.
      • MRGTX
        1,904
        740
        Sep 24, 2007
        CT, USA
        Local Time:
        1:24 AM
        Both ends? The body mount side on my car had the grease (and boots) but the suspension side, nada. That's really strange...
