Relay
Discussion in 'Electrical and Ignition' started by FrenchDragRacer, Sep 8, 2018.
  1. FrenchDragRacer
    FrenchDragRacer Active Member
    29
    0
    May 7, 2010
    Local Time:
    9:40 PM
    Hello from France!
    I try to remove my instruments cluster on my 71 Dart sedan because my fuel gauge don't run. I've remove this relay. Anybody know what is his function?
    Thanks!
    Picture find in internet
  2. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    47,084
    15264
    Jan 20, 2014
    CENTRURAL, PA
    View My Photos
    Local Time:
    3:40 PM
    Not a relay it is a current limiter for your gauges. It takes 12VDC and drops it to 5VDC, If your fuel and temperature gauge are not working good bet that is the culprit.
    • Agree Agree x 2
    • Dfr360cuda
      Dfr360cuda Well-Known Member
      807
      185
      Aug 30, 2012
      Finleyville, pa
      View My Photos
      Local Time:
      3:40 PM
      Check continuity / resistance.
    • FrenchDragRacer
      29
      0
      May 7, 2010
      Local Time:
      9:40 PM
      Ok thanks a lot !
    • 67Dart273
      67Dart273 Well-Known Member
      38,310
      5896
      Oct 14, 2010
      Idaho
      View My Photos
      Local Time:
      12:40 PM
      Recommend you replace it with an aftermarket solid state one. If you search, there are a few places show you how to build one using a 5V solid state regulator chip Get you started:
      RTE limiter - rte
      Making voltage regulator for dash gauges
      Mopar Voltage Regulator Upgrade
      Other problems with the clusters read this:
      Printed circuit pins repair
      1...Check the connector pins carefully for corrosion or looseness between board traces. They should be soldered to the board traces
      2....Connection contacts for the IVR often lose contact with the board traces. Solder bridges across as shown in the link above
      3....Gauge stud nuts lose contact with board traces. Loosen/ tighten nuts a few times to "scrub" them clean and consider replacing nuts with "regular" hex nuts
      There is resistance values for the senders derived from the old gauge tester (in the factory manuals) which is 3 resistances with a switch, used to substitute for the sender, giving you low scale, mid scale, and high scale, IE C--middle--H or E--1/2--F etc
      All gauge units are the same, oil, temp, fuel. They all read the same with the same sender resistance
      • Like Like x 1
      • FrenchDragRacer
        29
        0
        May 7, 2010
        Local Time:
        9:40 PM
      • 67Dart273
        38,310
        5896
        Oct 14, 2010
        Idaho
        View My Photos
        Local Time:
        12:40 PM
        Continuity tests tell you NOTHING on that device. You need to check it operationally as I detailed above using 12 jigged up to the proper cluster pin and cluster ground, and check the gauges response using test resistors substituted for the senders.
        Just.......replace....the.....device
      • FrenchDragRacer
        29
        0
        May 7, 2010
        Local Time:
        9:40 PM
