I thought I would check before I tossed it. I am cussing trying to sort out my new cable/throttle bracket/Eddy 1906 carb linkage and about to go Lokar anyway.a good bicycle shop or custom motorcycle shop could probably set you up with a custom cable.
once they're frayed like that, there's really no coming back and replacement is generally the best option-- generally because that means the inner liner is damaged as well.
that should pretty much be a slam dunk. you have the mopar throttle arm and stud that goes onto the stock eddy stuff?I thought I would check before I tossed it. I am cussing trying to sort out my new cable/throttle bracket/Eddy 1906 carb linkage and about to go Lokar anyway.
Bend it outward, and not just grab and bendThe bracket puts the cable too far inboard and it seems too far forward.
If i take the adaptor off it should line up… tbaBend it outward, and not just grab and bend
Put something between the bracket and value cover, or take it off, to give it a nice double curve or similar.
Bend the top to make it level again.
Drill extra holes to move the top part back farther.
Basically what I did when I had that setup.
