Repairing a plastic grill
Mopar Body and Trim
  1. nearpar
    nearpar Well-Known Member
    197
    40
    Sep 14, 2018
    The Motor City
    Local Time:
    8:08 AM
    Got a decent used plastic grill for my 72 Dart.
    This grill has a couple of broken mounting points and a small crack on the bottom.i do have the broken tabs that I am looking to reattach. I was wondering what some of you may of successfully used to make these kind of repairs. I want to reattach the original tabs and repair the crack.
    Thank for your help
  2. cdwmotorsports
    cdwmotorsports Well-Known Member
    275
    41
    May 22, 2004
    Martinsville , IN
    Local Time:
    8:08 AM
    I tried a good epoxy and it failed, but it was on the car and I left it unattended. I saw something shiny and went to work on it. I’m gonna try it again come summer. However I may just buy one of the new repop ones and be done.
  3. Alaskan_TA
    Alaskan_TA Well-Known Member
    5,263
    3425
    Nov 12, 2004
    PA
    Local Time:
    8:08 AM
    • Like Like x 3
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • Alaskan_TA
      5,263
      3425
      Nov 12, 2004
      PA
      Local Time:
      8:08 AM
      Missing corner that is hollow inside?
      No problem.........
      • Like Like x 6
      • cdwmotorsports
        275
        41
        May 22, 2004
        Martinsville , IN
        Local Time:
        8:08 AM
        Well I guess I’m gonna tackle a couple new projects this summer.
      • Alaskan_TA
        5,263
        3425
        Nov 12, 2004
        PA
        Local Time:
        8:08 AM
        Round hole in a missing corner on a complex surface?
        Again, no problem. A straw works as an inner form for the hole;
        • Like Like x 3
        • 4spdragtop
          4spdragtop Well-Known Member
          27,985
          7768
          Aug 28, 2009
          Wasting time here
          Local Time:
          7:08 AM
          JB Weld makes good stuff as well. I've used it on our 69 cuda grille and tail light lenses
          • Agree Agree x 4
          • JDMopar
            JDMopar Well-Known Member
            2,480
            1276
            Jan 19, 2012
            Candler, NC/Myrtle Beach, SC
            Local Time:
            8:08 AM
            If you can find a parts grill that is busted all to pieces for dirt cheap, buy it! Then take plastic pieces from the same area you want to repair, and scrape shavings off of that piece into a cheap glass dish. Then add a little bit of Acetone to the shavings and mix it up till it makes a gooey paste. You can then apply that goop to the V'ed out crack, and dab it into the V. Let it dry and then carefully sand it down smooth. Use the same method to reattach your broken off tabs. If you do it right, it won't bust back loose. Experiment on some pieces of the parts grill if you find one.
            I edited my post to read "Acetone" instead of Toluene, because Mtrhead jogged my memory and he is correct. I guess too much paint thinner made me remember the wrong paint thinner....lol.
            • Like Like x 2
            • Agree Agree x 1
            • Mtrhead
              Mtrhead Ace of Spades ♠️
              1,761
              474
              Sep 19, 2018
              S.C.
              Local Time:
              8:08 AM
              Acetone & shaved plastic mix and apply..will harden to good as new
              • Agree Agree x 1
              • jos51700
                jos51700 Well-Known Member
                5,145
                1832
                May 24, 2009
                Bel-Ray
                Local Time:
                7:08 AM
                I've heard that model glue for polystyrene works well.
              • Fgill
                Fgill Well-Known Member
                200
                227
                Feb 16, 2015
                ut
                Local Time:
                7:08 AM
                If the breaks are in or have an area (such as underside) which is not visable, I have had great results with using fiberglass weave, drywall tape, etc. lay it down after the basic repair is done and 'flood' it with epoxy. allow to cure. sand. 50/50 Duco & Krazy glue works amazing without the heat that many epoxies throw off.
                Often times an area that is busted will also show micro cracks around that broken area and is probably brittle to begin with. Renforcing it will make the repair last a long time.
                If you need a parts 72 grill, lmk.
                • Like Like x 1
                • jazak5
                  jazak5 Well-Known Member
                  701
                  267
                  Aug 6, 2015
                  NY
                  Local Time:
                  8:08 AM
                • TF360
                  TF360 Well-Known Member
                  1,422
                  406
                  Apr 25, 2014
                  Florida
                  Local Time:
                  8:08 AM
                  JB weld plastic epoxy. I had success with it
                  • Agree Agree x 1
                  • mcodecuda
                    mcodecuda Senior Member
                    519
                    123
                    Sep 17, 2007
                    Catawba NC Just a little north of Charlotte
                    Local Time:
                    8:08 AM
                    I’ve used a product call Plast-Aid to fix the plastic grills on many 69 barracudas with great success.
                  • moparmat2000
                    moparmat2000 FABO Gold Member FABO Gold Member
                    14,989
                    4536
                    May 13, 2010
                    Grand Tetons
                    Local Time:
                    7:08 AM
                    If its cracked and all the pieces are there and fit well together, just use MEK (Methyl Ethyl keytone) available at lowes in the paint department on a cut down acid brush on the cracked plastic. Just 1 drop will suck into the crack via capillary action. And will melt the plastic at the crack rebonding it together with it's own plastic. No V notching needed. It takes about a day to fully dry to handling, but you can clamp it together on the back side with a piece of sheetmetal and clamps till dry. I glued these shattered things back together with it. Missing pieces I used JB weld.
                    • Like Like x 2
                    • nearpar
                      197
                      40
                      Sep 14, 2018
                      The Motor City
                      Local Time:
                      8:08 AM
                      Wow Thank you that is amazing.
                      • Howard1784
                        Howard1784 Well-Known Member
                        606
                        87
                        Nov 3, 2009
                        Rochester, NY
                        Local Time:
                        8:08 AM
                        This stuff: Plastifix and Q bond
                        • Like Like x 2
                        • JoePole1
                          JoePole1 A dude in a B body FABO Gold Member
                          259
                          189
                          Mar 3, 2018
                          Hudson Valley, NY. NOT NYC!!
                          Local Time:
                          8:08 AM
                          Thank you all for your repair experiences. I was debating about buying a beat up instrument panel to customize and paint non-stock. I'm going for it now.
                          • Like Like x 1
                          • 4spdragtop
                            27,985
                            7768
                            Aug 28, 2009
                            Wasting time here
                            Local Time:
                            7:08 AM
                            I've got 2 beat up bezels if interested
                          • JoePole1
                            259
                            189
                            Mar 3, 2018
                            Local Time:
                            8:08 AM
                            Thanks but it's for a 72 Rallye B-Body.
                            • Like Like x 1
                            • nearpar
                              197
                              40
                              Sep 14, 2018
                              The Motor City
                              Local Time:
                              8:08 AM
                            • mcodecuda
                              519
                              123
                              Sep 17, 2007
                              Local Time:
                              8:08 AM
                              Plasticity looks to be the same as Plast-Aid except for the applicator. I use a glass eye dropper to add the activator to the powder when mixing Plast-Aid in bulk but I also like the needle type applicator with Plastifix so I’m ordering some today.
                            • Mattax
                              Mattax Just the facts, ma'am FABO Gold Member
                              8,935
                              5411
                              Feb 7, 2013
                              Phila. Pa
                              Local Time:
                              8:08 AM
                              Two different methods, 'welding' and bonding:
                              The chemicals best used for plastic welding depends on the plastic.
                              Some plastics can be welded with heat.
                              Some plastics can be bonded with adhesives (like epoxy) and some can't.
                              ABS is one of the more common plastics used for trim etc on cars.
                              More info in this thread
                              instrument cluster repair what glue to use
                              • Like Like x 2
