Replacement Engine Harness - Classic Industries
Electrical and Ignition
  1. GlennB4u
    GlennB4u Well-Known Member
    105
    30
    Oct 28, 2010
    Celina, Texas
    Local Time:
    2:13 PM
    Hey guys...
    I bought a new forward engine harness from Classic Industries for my 67 Barracuda FB... I have a couple questions about some wires that didn't exist in the one that I replaced it with..
    First, where does this purple w/white stripe wire on the battery side harness connect to? I had nothing that even resembled it on the harness I removed.
    [​IMG]
    And then on the passenger side... I'm assuming these connect to the coil with the grey one used for the temp sending unit?
    [​IMG]
  2. 1qwikScamp
    1qwikScamp Well-Known Member
    763
    5
    Aug 22, 2006
    soddy daisy TN
    Local Time:
    2:13 PM
    I ordered a new harness like that too it should have in the paper work what each wire is for. Some wires may not be used depending on how your car was optioned if you have extra wires that serve no purposes de-term them from your bulkhead
  3. GlennB4u
    105
    30
    Oct 28, 2010
    Celina, Texas
    Local Time:
    2:13 PM
    The paperwork says to use my current wiring as a guide... :???:
  4. 1969383S
    1969383S FABO Gold Member FABO Gold Member
    5,816
    2770
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    3:13 PM
    The purple/white kinda looks like the brake warning? Because of the boot.
    The other side gray should be oil pressure. The other 2 are covered so you can not see any colors.
    Seems they may offer a harness from M&H but that does not look like one. The M&H harness would be spot on. Is this harness a modified unit for electronic ignition?
  5. 1969383S
    5,816
    2770
    Jan 8, 2012
    Cumming, GA.
    Local Time:
    3:13 PM
    Look at this wiring doc.
    Violet/trace is Brake warning. The others are also shown on the engine harness page. Looks like a quality harness.
    • Like Like x 1
    • GlennB4u
      105
      30
      Oct 28, 2010
      Celina, Texas
      Local Time:
      2:13 PM
      Thanks Gerald... great info. My schematic was essentially unreadable.
    • 1969383S
      5,816
      2770
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      3:13 PM
      Great!!!
      Some of the colors changed for 68/69 looked weird to me at first until I looked at the 67 docs.
