Replacement fuel lines?
Fuel and Air Systems
  1. Troub
    Troub 67 Dart 270, 225 slant six
    182
    28
    Jul 25, 2018
    Florida
    Local Time:
    11:58 PM
    hello all,
    I'm looking for pre-bent fuel lines, main line tank to front, fuel pump to filter, filter to carb. (At least that's how my Dart was set-up when I got it). All the usual vendors list the front lines as fitting 2BBL carbs, 4BBLs, ect.......none that I see for a 1BBL. Also None that I see really look like my current ones.
    Any help is appreciated!
  2. MoparMike1974
    MoparMike1974 Well-Known Member
    985
    503
    Jun 16, 2017
    Maryland
    Local Time:
    12:58 AM
    As far as the carb goes, the only difference should be the line from the fuel pump to the carb. The rest should be the same. Just make sure you get the correct line for swinger or sport depending on what you have since there is a slight difference in length between the two.
    • Agree Agree x 1
    • Troub
      182
      28
      Jul 25, 2018
      Florida
      Local Time:
      11:58 PM
      It's a 270 with 225 slant six, I'll take some pics of the engine bay lines tomorrow and post. Thanks For the reply Mike.
    • Cuda Al
      Cuda Al Well-Known Member
      632
      462
      Oct 21, 2007
      Lompoc, CA
      Local Time:
      9:58 PM
      Contact Inline Tube, if you have originals they may be able to help you.
      They did a set of 8-3/4 brake lines for my C-Body that they didn't have listed.
      Alan
    • Hyper_pak
      Hyper_pak Old School Chrysler Fan
      1,621
      362
      Feb 14, 2010
      Desoto Texas
      Local Time:
      11:58 PM
      I bought stuff already bent, but it did not fit my wagon. I ended getting raw tube and bending my own. Good luck!
