Replacing ‘67 273 with a ‘78 318 questions
Small Block Mopar Engine
  1. Bobacuda
    Bobacuda Well-Known Member
    89
    110
    Dec 1, 2017
    Texas
    Local Time:
    6:53 PM
    2D4322A3-D12B-4637-A0F5-A5D6115BEB15.jpeg FC97D035-59CB-4083-A12A-ED36D37441B9.jpeg My ‘67 Barracuda convertible, Formula S, 273, PS, PB, automatic had its engine wiped out before I got it. The PO installed a ‘68 318 and did a lot of questionable mechanical, electrical and body work. I am in the process of rebuilding the car and undoing hooptie quality work. Which brings up all sorts of stuff I have never dealt with.
    These are the motor mounts that held the current engine, with no two bolts being the same. Are they correct for this use and do I buy new mounts for a 273 or a 318?
  2. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    4,569
    3552
    Jun 1, 2016
    Beach
    Local Time:
    4:53 PM
    One looks right, the one on the right.
  3. Bobacuda
    89
    110
    Dec 1, 2017
    Texas
    Local Time:
    6:53 PM
    The one on the left was DS, the one on the right was PS. The PO drilled two extra holes in the mount, then attached the insulator to a factory hole, at an angle.
    Anyone have photos of what they should look like?
  4. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    50,348
    15162
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    6:53 PM
    Here's photos of a 67 273 engine... The bolt heads should be toward the front of the engine, then slide the mount on from the rear and install the washers and nuts... Not all of them in the pictures have the bolts installed in the proper orientation... The bolts should be 3/8 fine thread...
    Driver's side:
    Passenger's side....
    • Agree Agree x 1
    • cosgig
      cosgig MoBro Inc. FABO Gold Member
      11,193
      4093
      Jul 20, 2008
      Pinckney, Michigan
      Local Time:
      6:53 PM
      Does it still have the original trans, and if so do you have an annular ring for the snout of the torque converter? If not it will just Waller out the front pump of the trans but quick.
      • Like Like x 2
      • Bobacuda
        89
        110
        Dec 1, 2017
        Texas
        Local Time:
        6:53 PM
        I’ll have to remove a couple of acres of New Mexico and oil from the trans to find out what year the 904 is. I suspect it came from the junkyard with the 318. How can I tell if it needs a annular ring? BTW, what does one look like - I’ve never heard of it.
        • Like Like x 1
        • krazykuda
          50,348
          15162
          Aug 20, 2007
          Orland Park, IL
          Local Time:
          6:53 PM
          Scrape off the New Mexico from the trans on the driver's side above the pan and below the linkages there should be some numbers stamped on the flat pad there... take a picture of those numbers and post them and they can be looked up to see what year the trans is....
        • nm9stheham
          nm9stheham Well-Known Member
          11,298
          3313
          Dec 20, 2013
          Waynesboro, VA
          Local Time:
          7:53 PM
          The snout on the TC is smaller diameter for '67 and earlier, than for thr '68 and later TC snout. So if that early TC was used, then a thin ring would be installed inside the larger, later registration hole in the back of the crank to fill in the gap in the diameters.
          • Like Like x 1
          • Bobacuda
            89
            110
            Dec 1, 2017
            Texas
            Local Time:
            6:53 PM
            So, measure the inside of the hole at the end of the crank on both engines, then measure the snout of the current TC. In a perfect world, the holes should be the same and the TC snout should measure close to the hole diameters, correct?
          • cosgig
            11,193
            4093
            Jul 20, 2008
            Pinckney, Michigan
            Local Time:
            6:53 PM
            correct!!
          • Bobacuda
            89
            110
            Dec 1, 2017
            Texas
            Local Time:
            6:53 PM
            Thanks for the info, folks.
          • 65Val
            65Val Average Length Member
            4,964
            939
            Oct 14, 2005
            Victoria, BC, Canada, EH!
            Local Time:
            4:53 PM
            Adapter/bushing looks like this...T-Flyte Patty use to sell them, but he's out of business now...
            ...and if the new engine has a cast crank, you'll need a B+M weighted flexplate to use with the old trans.
          • pt70
            pt70 Well-Known Member
            186
            107
            Aug 23, 2019
            CT
            Local Time:
            7:53 PM
            Boba; There is a lot of confusion about Mopar torque converters. I'm not sure about Magnums, but all 318's and all 273's are neutral balance, cast or forged crank. --------- All 360's and cast crank 340's are externally balanced. The weighted flexplate mentioned above is for mounting a 318/273 [neutral] converter to a 360 engine.
            65Val >> '' Average Length Member'' ……………. Please do not send photos !!!!!
            Thanks for the pic of the TC bushing.
          • 65Val
            4,964
            939
            Oct 14, 2005
            Local Time:
            4:53 PM
          • nm9stheham
            11,298
            3313
            Dec 20, 2013
            Waynesboro, VA
            Local Time:
            7:53 PM
            FWIW..... All 318's are cast cranks (except for some of the early forged truck cranks) and all 318's are internally balanced. So no external balanced flexplate or TC for any 318.
            Good pic of the ring! Tnx.
          • 65Val
            4,964
            939
            Oct 14, 2005
            Local Time:
            4:53 PM
            Cool...I stand corrected on the 318's. I thought late 60's 318's had forged (same as 273's), and went cast in the early 70's along with the rest of the engines?
          • Bobacuda
            89
            110
            Dec 1, 2017
            Texas
            Local Time:
            6:53 PM
            B65D15AD-B35D-4573-8976-6810715FC712.jpeg 1AE82EA2-C541-4E19-9DBE-D3620D27083F.jpeg IKrazyKuda - got to work on the mechanicals today. Took a couple of photos to get all the numbers.
          • 65Val
            4,964
            939
            Oct 14, 2005
            Local Time:
            4:53 PM
          • Bobacuda
            89
            110
            Dec 1, 2017
            Texas
            Local Time:
            6:53 PM
            Bolted to a ‘68 318 in a ‘67 Barracuda. Goes right along with the bodywork - rather than bolt the nosepiece to the fenders (factory), the PO welded the passenger side together. And I really wish he had bought some wires with more colors than yellow and green. So much to work through.
          • pt70
            186
            107
            Aug 23, 2019
            CT
            Local Time:
            7:53 PM
            Being average is ok. My wife never used my name and Johnny Wadd Holmes in the same sentence.
          • 66fyssh
            66fyssh Don't Stop Believin' FABO Gold Member
            4,613
            3149
            Jun 22, 2013
            Northwest GA
            Local Time:
            7:53 PM
            If you need an adapter bushing for the transmission to crank, @charliec is still selling them. I bought one from him a couple weeks ago.
          • Charrlie_S
            Charrlie_S Well-Known Member
            2,756
            639
            Oct 17, 2005
            Silver Springs, FL
            Local Time:
            7:53 PM
            I think you mean me. Yes I have the bushings available. Message me if you need one.
          • 66fyssh
            4,613
            3149
            Jun 22, 2013
            Northwest GA
            Local Time:
            7:53 PM
            Oh crap, sorry. I had the wrong screen name. Glad you saw the posting so you can help others.
