mopower440
I got the K-H setup installed on my dart finally and i have 3 studs that need to be changed. 2 of them look fine but known good nuts will not screw onto them. I bought a cheap die from harbor freight and it broke so im done playing around with it and just want to replace the studs. Can anyone explain this procedure? Im sure i have to take the center nut off and remove the hub/rotor assembly and beat them out?
