1. Ron816
    Ron816 Member
    19
    7
    Nov 15, 2019
    Quincy, MA
    Local Time:
    7:58 PM
    I just aquired a 68 GTS 4speed H code, question is would you keep the manual brakes & steering or upgrade to power?
  2. Dartsun
    Dartsun Member
    897
    522
    Feb 12, 2012
    Springfield Oregon
    Local Time:
    4:58 PM
    If it was my car I’d leave it manual.
    • Agree Agree x 2
    • 4spdragtop
      4spdragtop FABO Gold Member FABO Gold Member
      27,416
      7098
      Aug 28, 2009
      Ontario
      Local Time:
      6:58 PM
      Drum or disc brake on front? If drum, I would upgrade to factory disc.
    • Ron816
      Ron816 Member
      19
      7
      Nov 15, 2019
      Quincy, MA
      Local Time:
      7:58 PM
      Drums front and rear
    • Dartsun
      Dartsun Member
      897
      522
      Feb 12, 2012
      Springfield Oregon
      Local Time:
      4:58 PM
      I’d try to find some kelsey hayes brakes assuming your GTS still has small bolt pattern wheels. It’ll keep car manual brakes I used a 15/16 bore master on my 65 and I like the way it stops now.
      • Agree Agree x 1
      • 4spdragtop
        27,416
        7098
        Aug 28, 2009
        Ontario
        Local Time:
        6:58 PM
        Our 67 S came with factory disc and work perfectly fine. They are non power and the S is a small block. Now with yours and being a big block, I would definitely go disc at the least. You could either go aftermarket or factory. But definitely get front discs.
        • Agree Agree x 1
        • Car Nut
          Car Nut Mopar Master
          5,826
          24912
          Dec 28, 2018
          Zombieland
          Local Time:
          5:58 PM
          :welcome: aboard!
        • Ron816
          Ron816 Member
          19
          7
          Nov 15, 2019
          Quincy, MA
          Local Time:
          7:58 PM
          I don’t like the look of the power brake booster so I was thinking of keeping the manual master
          • Like Like x 1
          • forphorty
            forphorty Well-Known Member
            640
            222
            Jan 19, 2006
            Local Time:
            6:58 PM
            Yep, the brake booster on A bodies looks hideous and takes up a lot of space.
          • Yunick13
            Yunick13 Well-Known Member
            428
            602
            Sep 7, 2019
            At the fork in the road.
            Local Time:
            6:58 PM
            Power steering would be a nice upgrade, power brakes isn’t necessary if they’re set up properly.
            Welcome
            To
            The
            Forum
            :welcome:
          • My 72 340
            My 72 340 Well-Known Member
            888
            256
            Sep 22, 2013
            Erie, PA
            Local Time:
            7:58 PM
            I got non power 4 wheel drums on my Duster, been in a couple situations where some nut would pull out from a side road that required some moderate to hard braking, they haven't failed me yet.
          • Dartnut
            Dartnut Don't hate me because i'm beautiful
            10,304
            2403
            Apr 19, 2007
            Southern Alberta
            Local Time:
            5:58 PM
            Welcome to the site, my vote is for disc brakes too.
            However, I would go with the bbp discs from a '73 and up a-body, and put bbp axles in the rear.
            They are better than the sbp brakes and the parts are a lot cheaper and easier to find to boot.
            I would also keep the manual brakes, just use the 15/16'' pistoned master cylinder.
            IF you are doing a TRUE restoration, keep the 10'' drum brakes and manual master it came with and rebuild both, they really aren't as bad as some people think when they are in good working order..........
            • Like Like x 1
            • Agree Agree x 1
            • Ron816
              Ron816 Member
              19
              7
              Nov 15, 2019
              Quincy, MA
              Local Time:
              7:58 PM
              I'm going to keep what the car was born with.
              • Like Like x 2
              • Dartnut
                10,304
                2403
                Apr 19, 2007
                Southern Alberta
                Local Time:
                5:58 PM
                Good choice.
                • Agree Agree x 1
                • 4spdragtop
                  27,416
                  7098
                  Aug 28, 2009
                  Ontario
                  Local Time:
                  6:58 PM
                  And like dartnut said if you decide later on to change, the bbp stuff will be easier to find and cheaper.
                  • Thanks! Thanks! x 1
                  • Stephen Hotz
                    Stephen Hotz FABO Gold Member FABO Gold Member
                    1,211
                    1023
                    Dec 30, 2017
                    New Braunfels, Tx
                    Local Time:
                    6:58 PM
                    Welcome
                  • missing linc
                    missing linc Loose nut behind the wheel FABO Gold Member
                    631
                    740
                    Feb 17, 2019
                    Southern Alberta Canada
                    Local Time:
                    5:58 PM
                    Welcome, I would definitely stick to non power brakes, when set up correctly they work fine, though I would swap in disc fronts for safety if you plan on driving the car much.
