Reverse light wiring
cuda guy
Hi all
Im using a EZ Wire kit and I'm stumped on how to wire in the reverse light
Do I use the safety neutral switch or something else
Anyone that has used there kit knows the instructions are useless
Thanks
Richard
What year?
What car?
Automatic / manual
Column or console shifter
1968 cuda
440 727 automatic
Aftermarket floor shifer
Do you have a 1 or 3 pin neutral switch. If you have a 1 pin, that is neutral only, and the pin goes up to the starter relay to complete the coil circuit.
If you have only 1 pin transmission, the reverse switch is on the shifter
If you have a 3 pin, the reverse are the two outer pins, NS is center pin
3 pin
How do I wire it into a EZ wire harness
You need to post the destructions. What does the EZ book say. It should show you at least in general. It's a switch. EZ should show a power wire for them, and that goes to the switch, and the wire leading to the rear for the lights, and that goes to the switch. Since EZ is GM / Ford all the time ALL the time, they may not provide wiring through the bulkhead for this, you'll have to add wire
