Ride height adjustment
Cravin'sCuda
Novato
I recently rebuilt the front end and today installed the engine and is there a spec for ride height? I installed big block t-bars and wanted to finish the front end up with the engine in. Where would I measure from-motor mount,pan rail, etc to the ground. Thanks
There is an "official"way to do it with a "ride height guage"
But I always just set it were I like the way it looks,then mesure from the center of the wheel opening to the ground on a level floor and make both sides match. Do this BEFORE you do the alignment!!!
Hope this helps.
