1. phaelax
    phaelax Well-Known Member
    321
    79
    Sep 3, 2014
    Ohio
    Local Time:
    2:31 PM
    About a month ago, just before the mopar nats, my driver front rim started scraping my caliper. It was bent and twisted, shop said they can't fix the weld racing wheels due to how they're constructed. Bought a new rim from jegs, drove around a few blocks and it's been parked for the past few weeks. Took it out today, the new rim is doing the same thing now! I checked the other side and I have about 2" of clearance from the caliper to the inside of the rim, but on the driver side it's scraping again.
    What busted/bent part could be causing my wheel to do this?
  2. BigBlockMopar
    BigBlockMopar BigBlockMember
    1,616
    571
    May 1, 2011
    Netherlands
    Local Time:
    8:31 PM
    Pics!
    • Agree Agree x 2
    • GeorgeH
      GeorgeH Well-Known Member
      8,531
      3256
      Sep 23, 2014
      laurel delaware
      Local Time:
      2:31 PM
      Pics would be good. Of the hub/rotor or whatever set up you have going on. I would think if something was majorly bent or broken you would feel something goofy going on before you got up to speed, or at speed. A wobble, shake or some other goofy steering/bumpsteer issue. I've said it before and it turned into an arguement but some Weld's just don't like potholes and other roadhazards or sideloading.
    • phaelax
      321
      79
      Sep 3, 2014
      Ohio
      Local Time:
      2:31 PM
      The ride feels fine, no vibrations or wobbling. But like I said, this is a brand new Weld wheel with less than a dozen miles on it. I'll go try to take a pic.
    • diymirage
      diymirage HP@idle > hondaHP@redline
      15,623
      8139
      Oct 12, 2012
      michigan
      Local Time:
      2:31 PM
      swap wheels left and right and report back...my money is on a busted spindle
    • GeorgeH
      8,531
      3256
      Sep 23, 2014
      laurel delaware
      Local Time:
      2:31 PM
      There's only a few things that would let the wheel hit the caliper. It could be caliper or bracket bolts missing, the wheel bearings are shot, which you would feel, the hub is cracked, the knuckle itself is flexing that much, which I don't seeing happening but stranger things have happened, or the wheel is flexing. A new wheel is not going to be designed any different then the old one. The ones I used, Draglite's and Prostar's don't like 90mph off-ramp sweepers, and buying more won't make the wrong wheel the right one for that job.
      • Like Like x 1
      • phaelax
        321
        79
        Sep 3, 2014
        Ohio
        Local Time:
        2:31 PM
        That's what I just did, wheel spins fine on other side.
        I should've noticed this when I replaced the wheel the first time, but honestly I wasn't looking for anything else at the time as I thought the wheel just failed. Even the shop next to me showed me the wheel was warped when he stuck it on the balancer it was clear as day. Figured buy new rim, call it a day.
        Notice anything off about the caliper?
      • phaelax
        321
        79
        Sep 3, 2014
        Ohio
        Local Time:
        2:31 PM
        I didn't want to buy two new wheels that week, and I was trying to get my car to the nationals the following day so I just replaced the bad one. (another issue prevented me from taking it that weekened anyway)
        • Agree Agree x 1
        • GeorgeH
          8,531
          3256
          Sep 23, 2014
          laurel delaware
          Local Time:
          2:31 PM
          It's not all the way down.
          • Agree Agree x 1
          • halifaxhops
            halifaxhops It's going to get stupid around here! FABO Gold Member
            51,337
            18971
            Jan 20, 2014
            CENTRURAL, PA
            Local Time:
            2:31 PM
            Not much on with the caliper mount either!
          • phaelax
            321
            79
            Sep 3, 2014
            Ohio
            Local Time:
            2:31 PM
            I reseated the caliper and tightened everything back down, it's all lined back up properly. But there seems to be too much play in the caliper. I've never messed with calipers like these before, are those two thin pieces of tin really all that holds that big heavy clunker on there?
          • halifaxhops
            51,337
            18971
            Jan 20, 2014
            CENTRURAL, PA
            Local Time:
            2:31 PM
            Yup that is all. Check the two bolts that attach the bracket to the spindle also, should be really tight, if still have play get new hold downs at any auto parts store can order them.
          • BigBlockMopar
            1,616
            571
            May 1, 2011
            Netherlands
            Local Time:
            8:31 PM
            There's no way you could 'just reseat the caliper' and all be alright again.
            Something is still major 'upped for the caliper to work its way outward like that.
            Check the bracket it's mounted too. Check for a missing (large) bolt.
            The pins just locate the floating caliper and brake-pads. The bracket carries the brake-load to the spindle, when brakes are applied.
            OTOH, I don't see yet how a caliper could bend a wheel like you described, and even when you don't or hear anything 'funny' while driving.
            • Agree Agree x 1
            • phaelax
              321
              79
              Sep 3, 2014
              Ohio
              Local Time:
              2:31 PM
              I took the bracket off too, so that's back on nice and tight also.
              I'm blaming the guys that did my engine swap and supposedly my front suspension. But I've been having more issues with this car since they "fixed" it than ever.
            • halifaxhops
              51,337
              18971
              Jan 20, 2014
              CENTRURAL, PA
              Local Time:
              2:31 PM
              Almost looks like he did not seat the caliper right and just slapped the hold down on. Pretty hard to do actually!
            • phaelax
              321
              79
              Sep 3, 2014
              Ohio
              Local Time:
              2:31 PM
              It's possible the rim bent from something entirely unrelated. The new rim, as far as I can tell, doesn't appear to actually be bent. I kind of assumed it was when I heard it rub the caliper again. But I put it on the other side and it seems fine.
              I just ordered new clips, $2 but it'll take a few days.
            • BigBlockMopar
              1,616
              571
              May 1, 2011
              Netherlands
              Local Time:
              8:31 PM
              Clips?
              Any clear pics of the backside of the caliper and bracket?
            • phaelax
              321
              79
              Sep 3, 2014
              Ohio
              Local Time:
              2:31 PM
            • halifaxhops
              51,337
              18971
              Jan 20, 2014
              CENTRURAL, PA
              Local Time:
              2:31 PM
              You want the small ones that go on top of those also.
            • BigBlockMopar
              1,616
              571
              May 1, 2011
              Netherlands
              Local Time:
              8:31 PM
              Ok, looked a bit better at the pic you posted, you don't have pin-type calipers so disregard my previous reply about the pins.
            • halifaxhops
              51,337
              18971
              Jan 20, 2014
              CENTRURAL, PA
              Local Time:
              2:31 PM
              • Agree Agree x 1
              • phaelax
                321
                79
                Sep 3, 2014
                Ohio
                Local Time:
                2:31 PM
                I can't seem to find just the retainer clip for sale. Classic industries has it with a piston rebuild kit but that's all I've found.
              • Plymouth Pete
                Plymouth Pete Well-Known Member
                99
                49
                Nov 9, 2015
                Windy City 3300 W Grand
                Local Time:
                1:31 PM
                WAGNER KIT H5516 at Rock Auto
                • Thanks! Thanks! x 1
