Ring and Pinion - What Brand ?
Transmission and Drivetrain Tech
  1. RPMagoo
    RPMagoo Just An Old Motorhead
    3,100
    1590
    Nov 4, 2015
    N.E. Pa.
    Local Time:
    3:20 AM
    Car is a "Brand X". --- -- I'm planning to buy a new ring and pinion for My Ford, 8" posi, rear. -- Looking for suggestions re best brand to get. --- Thanks
  2. Steven190
    Steven190 FABO Gold Member FABO Gold Member
    1,105
    538
    Jan 13, 2012
    Omaha
    Local Time:
    3:20 AM
    Richmond of course
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • supertruck
      supertruck Retired Old Fart stock car racer FABO Gold Member
      606
      300
      Feb 14, 2016
      Gloucester, Va
      Local Time:
      4:20 AM
      I've used Motive Gear in my street car and circle track car. No issues at all. Proper installation is the key with any brand.
      • Agree Agree x 1
      • RPMagoo
        3,100
        1590
        Nov 4, 2015
        N.E. Pa.
        Local Time:
        3:20 AM
        -- I've heard that they are a real good gear, but that's what I have. - They were new, and howled. -- They were set up 3 times, by 2 different guys (one Guy 2 times - other Guy one time) who have done, probably, 100, or more setups. - still howl at 55 - 60 MPH. -- Less than 200 total miles on the current gears. - Now i'm having them replaced, and don't know if I should switch brands. -- Thanks for the info.
        • Like Like x 1
        • moparmat2000
          moparmat2000 FABO Gold Member FABO Gold Member
          15,863
          5149
          May 13, 2010
          Grand Tetons
          Local Time:
          3:20 AM
          Hit pick n pull grab a set of used 8.8 gears out of an explorer 8.8 factory Ford gears will set up easier, and may work with existing shims in the same locations as the old gears. Second plus will be the cost compared to new. Look at the data tag for the set you want. On explorers they come in 3.23, 3.55, 3.73, 3.90, and 4.10 ratios. Most common gear will be the 3.55 on V6 sports, and 3.73 on V8 XLT. The 4.10 gear was standard on the sport trak truck looking thing. Happy hunting. Whoops ford 8 inch is different than an 8.8. Disregard
        • RPMagoo
          3,100
          1590
          Nov 4, 2015
          N.E. Pa.
          Local Time:
          3:20 AM
          -- Yep !! -- But, thanks for the thought.
          • AJ/FormS
            AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
            18,095
            6380
            Jan 19, 2014
            South-Central Manitoba,Canada, 900ftelevation
            Local Time:
            3:20 AM
            Since it requires very specialized tooling to make gears, I wonder if it matters.
          • RPMagoo
            3,100
            1590
            Nov 4, 2015
            N.E. Pa.
            Local Time:
            3:20 AM
            -- Don't know. -- I've spent quite a bit of time searching this topic, and find that Richmond Gears get a lot of bad comments re noise, although many say that is probably a set up problem. -- I'm very interested in all of this, because I'm tired of pulling the rear to, hopefully, quiet it at, normal, highway speeds. -- If this continues, I'll have to go back to Mopar. -- :D --
          • AJ/FormS
            18,095
            6380
            Jan 19, 2014
            Local Time:
            3:20 AM
            My personal experience is that if a properly set up gear-set is noisy on day one, you already saw it would be, when you patterned it, but maybe just didn't see it.
            If you run it that way for some small period of time ( I can't be specific, as I don't know), then it will always be noisy... forever.
            I also know that a very slightly noisy pumpkin, in an Abody; if you install that in a Challenger/Cuda, the noise will be greatly magnified in it's new home.
            The only aftermarket experience I have had is with Richmond, and the 4.30s I bought new and installed were dead quiet.
            Good luck to you
            • john-9
              john-9 Well-Known Member
              145
              60
              May 11, 2015
              Oldcastle , Ontario
              Local Time:
              3:20 AM
              get a ring and pinion set made by US GEAR ( NOT US Standard Gear ) -- made in the USA ,,, available from Summit , Strange Engineering , Quick Performance etc . --- Motive Gear bought out Richmond Gear several years ago , box is Richmond but a Motive gear inside--
              your problem is a set up issue -- pinion depth shim incorrect or more than likely pinion bearing preload not set properly
              if you buy a set of US Gears , they come from the factory with a gear pattern run on them --take a picture of the pattern as this is the gear pattern you should strive for in your set up then get the pinion bearing preload right ( 20-25 inch pounds new bearings -- 10-15 used bearings )
              • RPMagoo
                3,100
                1590
                Nov 4, 2015
                N.E. Pa.
                Local Time:
                3:20 AM
                -- Looks like Motive Gear and Richmond are separate companies, owned by - Midwest Truck and Auto Parts. -- BTW -- I plan to buy those gears. -- Thanks for the info. Midwest Truck | Aftermarket and OEM Manual drivetrain components
              • RPMagoo
                3,100
                1590
                Nov 4, 2015
                N.E. Pa.
                Local Time:
                3:20 AM
              • 69_340_GTS
                69_340_GTS Well-Known Member
                3,864
                1747
                Jul 11, 2014
                Torrington, CT
                Local Time:
                4:20 AM
                If you want the run-in gears from U.S. Gear note that they are at least 1.5X the price of the regular ones. They sell the 8" Ford "everyday" gears for $220-$250, but the 8" Ford run-in "Lightning series" are $350-$370. I have never heard anything bad about them, however.
                • RPMagoo
                  3,100
                  1590
                  Nov 4, 2015
                  N.E. Pa.
                  Local Time:
                  3:20 AM
                  -- I'm getting these, from Summit.
                • A Body 440 WHY NOT
                  A Body 440 WHY NOT Well-Known Member
                  145
                  44
                  Sep 28, 2019
                  Jersey
                  Local Time:
                  1:20 AM
                  US gear. Strange . same . Really good stuff.
                  (Not USA gear.)
                  IMO.
                  • Agree Agree x 1
                    145
                    44
                    Sep 28, 2019
                    Jersey
                    Local Time:
                    1:20 AM
                    I would get the US Gear ( strange) If hey don't offer the gear you want, go to Richmond. Richmond makes 2 levels of gears. Premium set is a "diamond cut "gear. Spend a little more , you will be glad u did.
                    • Like Like x 1
                    • RPMagoo
                      3,100
                      1590
                      Nov 4, 2015
                      N.E. Pa.
                      Local Time:
                      3:20 AM
                      • Like Like x 3
                      • lemondana
                        lemondana BlackDart
                        394
                        198
                        Dec 7, 2007
                        Southeast NE
                        Local Time:
                        2:20 AM
                        Find NOS O.E Ford gears. Original Equipment gears are always the best, and surely still made in the U.S.A
                      • RPMagoo
                        3,100
                        1590
                        Nov 4, 2015
                        N.E. Pa.
                        Local Time:
                        3:20 AM
                        -- See post #17 -- In transit.
