Gadabout
The wires for the dash got roasted at some point, and the need repair or replacement. Where can I find this item or should I go with a universal kit? I am having trouble downloading pictures from phone.
A. Find out a out what fried, and then we can figure out why it fried.The wires for the dash got roasted at some point, and the need repair or replacement. Where can I find this item or should I go with a universal kit? I am having trouble downloading pictures from phone.
Chrysler Valiant V200 Station Wagon Road Test 1960 (2) by Trigger's Retro Road Tests!, on FlickrWell its good that you've started to look into it.As to the root cause of what caused the wires to overheat and melt the insulation, Jerry, the mechanic, believes it to be a thin, brittle, under-gauge wire that went from the battery or something; I am guessing it is a positive feed, and it failed to transmit enough juice and this in some way caused the dash wiring to heat up enough to melt the dash wiring harness. It was replaced with a heavy gauge feeder wire when the alternator was replaced a few months ago. Until then, the wipers still functioned, then they stopped entirely.
I will be downloading these photos and schematics, as well.It's great that your buying a 1960 Valiant factory service manual because the online diagrams shown up to this point don't match the one in the factory manual. Some of them are similar but not close to an exact match.
