1. 68383GTS
    68383GTS Well-Known Member
    7,378
    973
    Nov 15, 2007
    East Peoria,IL
    Local Time:
    7:49 AM
    Has anybody used one of the flywheels from Rockauto? I need one for a 1974 318. I assume Rockauto flywheel are China made. I just do not want to replace it 5000 miles down the road. But I really do not want to spend $400 on a flywheel.
    • Like Like x 1
    • Scody21
      Scody21 Just send it
      1,007
      1029
      Jul 17, 2019
      Southwest Washington Coast
      Local Time:
      5:49 AM
      Look at Ram flywheels.
      1503 - Steel flywheel Chrysler 6 bolt 130 tooth - RAM Clutches
      Can get the SFI sticker with it for no added cost...
      • Like Like x 1
      • Thanks! Thanks! x 1
      • ch1ll
        ch1ll FABO Gold Member FABO Gold Member
        1,215
        618
        Jun 12, 2009
        Belgium,wi
        Local Time:
        7:49 AM
        If you’re going to buy a flywheel, for gods sake and your safety, buy a steel one.
        • Agree Agree x 3
        • Like Like x 1
        • Professor Fate
          Professor Fate Push the button, Max...
          2,469
          3348
          Jan 13, 2020
          Wisconsin
          Local Time:
          7:49 AM
          RockAuto does not make parts, they are a reseller. They deal in manufacturer overstocks, dealer liquidations, closeouts, etc. for the most part.
          Take your flywheel, for example. They probably list several different ones, all different manufacturers. You'd have to look up the manufacturer of the one you're looking at to find out the country of origin (yes, most all are made in China now, regardless of brand). Most of their parts are the same ones you get at O'Reilley's, Autozone, NAPA, Advance Auto, CarQuest, etc. Quality varies between brands, as always.
          • Agree Agree x 6
          • Like Like x 1
          • lead69
            lead69 hopeless car junkie
            1,495
            747
            Nov 5, 2006
            Vancouver,Wa
            Local Time:
            7:49 AM
            • Agree Agree x 2
            • Like Like x 1
            • 69cudaownr
              69cudaownr FABO Gold Member FABO Gold Member
              286
              198
              Aug 21, 2008
              Waterloo, Ontario, Canada
              Local Time:
              8:49 AM
              Yes, on my 318. Have not had a problem. Its a daily driver car.
            • pishta
              pishta I know I'm right....
              21,388
              10777
              Oct 13, 2004
              Tustin, CA
              Local Time:
              5:49 AM
              and you can bet your ass they are cast (billeted forged?) in China. Reason I say this is that its not Chinese that is crap in general, its the spec its called out to from the customer. If it were made in USA, it would be plastered all over that ad. Plenty of stuff on new cars is Chinese origin. If 440-source is selling it, its probably been vetted by them as they are run by enthusiests and most likely would not sell an inferior product again (their restricted passage aluminum water pump housings gave them a black eye already)
            • lead69
              1,495
              747
              Nov 5, 2006
              Vancouver,Wa
              Local Time:
              7:49 AM
              Agreed, so is my crank, my rods, ignition parts, almost 80% of auto parts. Sadly half the stuff I get with made in the usa on it is crap, new small block edlebrock head castings vs. speedmasters for example.
            • jos51700
              jos51700 Green Bearing thread connoisseur
              5,956
              2731
              May 24, 2009
              Bel-Ray
              Local Time:
              7:49 AM
              Imma disagree and agree at the same time.
              I'll admit, not everything from China is shit. I guarantee that what ever weapons they're building to attack us with will be top notch
              The problem with China is consistency. You never know if this flywheel is the one with a void in it.....
              • Agree Agree x 1
              • pishta
                21,388
                10777
                Oct 13, 2004
                Tustin, CA
                Local Time:
                5:49 AM
                Imma disagree on the Chinese weapons..Chinese stuff encountered in Vietnam was crude, but the numbers will be on their side. Training will be where we excel. They got 99 reasons NOT to scrap with us, and 98 involve (our) economy keeping them afloat.
                • Like Like x 1
                • Krooser
                  Krooser Building Chinese Free Engines since 1959...
                  3,360
                  2937
                  Jul 19, 2015
                  Central Wisconsin
                  Local Time:
                  7:49 AM
                  Chinese...great food crappy parts.
                • Vinny
                  Vinny Member
                  24
                  1
                  Dec 21, 2006
                  Bergen County, NJ
                  Local Time:
                  8:49 AM
                  Why don’t you get your original one resurfaced? It is an option if is not scored too badly. Good luck.
                  • Agree Agree x 1
                  • nckennyb
                    nckennyb Well-Known Member
                    61
                    22
                    May 8, 2014
                    NC
                    Local Time:
                    8:49 AM
                    I'm running one of those flywheels from 440 Source in my 340 Dart and have not had any problems with it. It came with a counter weight bolted to it for external balance engines but just remove it for internal balance application. I see the referenced ad now says internal balance only. I don't have a shattershield so I wanted to at least have a little insurance against a flywheel failure and I thought this steel one would do the trick.
                  • Tracey-speed003
                    Tracey-speed003 Muscle Car Lovin Guy
                    83
                    67
                    Apr 16, 2019
                    Spokane Valley, Washington
                    Local Time:
                    5:49 AM
                    Check out Brewers Performance also, The Mopar 4 speed gurus, FW598N 199.95
