Rocker arm play
Discussion in 'Small Block Mopar Engine' started by moparker, Jun 11, 2018.
  1. moparker
    moparker Well-Known Member
    1,749
    30
    May 25, 2008
    Local Time:
    12:53 PM
    Should there be any side to side movement on stock rocker arm assemblies?
  2. 72Dart6pack
    72Dart6pack Harder Better Faster Stronger.
    2,694
    1731
    Feb 1, 2016
    Roseville Michigan
    Local Time:
    1:53 PM
    There is a spec for side to side play. Like .030 but don't hold me to that number. Other guys will chime in.
    • Like Like x 1
    • moparker
      1,749
      30
      May 25, 2008
      Local Time:
      12:53 PM
      I hope. I'm sure that is the irritating ticking noise I'm hearing. My retainers don't look that bad to me. I think I have more play than that.
    • Plymouth 65
      Plymouth 65 Floorable Deplorable
      584
      374
      Jun 27, 2016
      Mich
      Local Time:
      1:53 PM
      Stock cam and valve springs? 65'
    • yellow rose
      yellow rose Doctor of Thinkology.
      15,415
      12016
      Jun 19, 2015
      Living on the razors edge
      Local Time:
      10:53 AM
      .030 is ok but if you are AR about it you can shim them to .015. That's what I do because I'm retarded like that. If you have to shim to .030 why not close it up a bit more.
    • 72Dart6pack
      2,694
      1731
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      1:53 PM
      You do want some side play. When the parts get warm they grow a little. Someone will know the spec. Just hold tight.
    • moparker
      1,749
      30
      May 25, 2008
      Local Time:
      12:53 PM
      Not stock can and valve springs. I have a Lunati can with double springs.
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      2,771
      1749
      Jun 1, 2016
      breakwater
      Local Time:
      10:53 AM
      I share the same retention...lol... I try for .010-.015... but once you tighten it back down and torque it you usually find that there's always a lil extra still.
      Op, Too much on a solid high lift and you will here the rocker hit the one next to it
    • moparker
      1,749
      30
      May 25, 2008
      Local Time:
      12:53 PM
      My cam is hydraulic but, is on the larger side. I was wondering if that had anything to do with it. Could someone post pics of the shims and exactly where they placed them?
    • flyfish
      flyfish C8H18+N2O = :-D
      1,680
      172
      Apr 16, 2007
      Indy
      View My Photos
      Local Time:
      1:53 PM
    • moparker
      1,749
      30
      May 25, 2008
      Local Time:
      12:53 PM
    • IQ52
      IQ52 Well-Known Member
      2,255
      1426
      Jul 30, 2011
      Idaho
      Local Time:
      11:53 AM
      • Like Like x 1
      • Agree Agree x 1
      • moparker
        1,749
        30
        May 25, 2008
        Local Time:
        12:53 PM
        So it's ok to use the spacers on a hydraulic set up? All the spacers kits say they are for solid cams.
      • Wyrmrider
        Wyrmrider Well-Known Member
        877
        277
        Sep 5, 2016
        los angeles
        Local Time:
        10:53 AM
        Big Hyd cam
        check for stem tip wear and rocker pad
        think lash caps to spread out the load
        when shiming try to line up the rockers on the tips
        what does the tip wear pattern look like when your die the stems and turn the motor over? you want as narrow as possible
        throw some adjustable pushrods on it and adjust shaft height till you get narrowest pattern then check against your pushrod length- watch for leaker bleed down or use a solidized lifter--if new lifters use the MAgnum/ AMC style and hollow pushrods to save those pushrod cups in the stock rockers
        do the complete mid lift geometry drill- you may need shims under the shafts
        not only ok to use with hyd but necessary with a big cam
      • nm9stheham
        nm9stheham Well-Known Member
        9,724
        2158
        Dec 20, 2013
        Waynesboro, VA
        Local Time:
        1:53 PM
        Spacers are fine for either. The existing spacers under the bolt heads can be moved around too.
        I have not ever seen a spec in this for the stamped rockers BTW. And not trying to be obtuse, but there are much more likely causes for this tapping/ticking, so make sure you look at everything:
        - a soft hydraulic lifter
        - pushrods hitting the sides of the pushrods holes due to high lift (spacers could make this worse)
        - retainers hitting the seals/stem guides for there same reason
        - rocker hitting the baffle on the underside of the valve cover
        • Agree Agree x 1
        • moparker
          1,749
          30
          May 25, 2008
          Local Time:
          12:53 PM
          It's definitely not a lifter tick. It could be some of the causes you named. Thanks for all the input.
        • nm9stheham
          9,724
          2158
          Dec 20, 2013
          Waynesboro, VA
          Local Time:
          1:53 PM
          And FWIW.... I also suspect the loose side clearance for the stamped rockers has to do with:
          - The way they oil (With the stamped slot in them, there is really not the same oiling out the sides like in machined rockers.)
          - They won't all ride perfectly parallel to each other on the shaft. Being stamped, there is a limit to the parallelism that just can't be as good as a machined part. So some slop is necessary.
          Let us know if this does the trick for your tick.
          • Agree Agree x 1
          • mullinax95
            mullinax95 Well-Known Member
            12,885
            325
            Oct 25, 2006
            Anderson, SC
            View My Photos
            Local Time:
            1:53 PM
          • moparker
            1,749
            30
            May 25, 2008
            Local Time:
            12:53 PM
            Thanks. A friend of mine who is career mechanic has been doing some research as well. A lot of guys are having this issue. Some have found it was the thickness of the head gaskets causing the problem.
          • famous bob
            famous bob mopar misfit
            11,013
            2668
            Aug 14, 2011
            okla
            Local Time:
            12:53 PM
            agree w/ this ^^^^^^^^^^^^^^^^^^^
            I don`t have stock rockers, and use .010-.012 feelers between each rocker arm, and leave them in while tightening the shaft bolts down. Keeps things more accurate for me.
          • MOPAROFFICIAL
            2,771
            1749
            Jun 1, 2016
            breakwater
            Local Time:
            10:53 AM
            Sometimes you end up grinding on the hold downs to get it just right.
            All the aftermarket rocker assemblies I use come with the black spacers, I think they are about .080 thick.
          • nm9stheham
            9,724
            2158
            Dec 20, 2013
            Waynesboro, VA
            Local Time:
            1:53 PM
            Running the hydraulic lifter adjustment out of range?
          • moparker
            1,749
            30
            May 25, 2008
            Local Time:
            12:53 PM
            Not sure what you mean. If the gaskets are to thick then there won't be as much or any tension or load on the rockers to keep them in place.
          • nm9stheham
            9,724
            2158
            Dec 20, 2013
            Waynesboro, VA
            Local Time:
            1:53 PM
            I think this is what you are meaning: There is not a lot of tension and it only comes from trapped oil in the piston that can move inside the lifter. The tension/pressure is pretty constant as the head moves up or down with gasket thickness, but the lifter's piston has a short movement/adjustment range. If the heads lift up too much, the piston can reach its upper stop and then a gap opens up between the lifter's piston, pushrod and rocker.
            But side shims won't change/fix that loose situation.
          • moparker
            1,749
            30
            May 25, 2008
            Local Time:
            12:53 PM
            That's what I'm gathering as well. Gonna do some measuring soon and get a better idea of what I need to do.
