Rocker arm side play
Slant 6 Engines
  1. TAK65
    TAK65 Well-Known Member
    128
    67
    Aug 17, 2015
    Helsinki
    Local Time:
    4:10 AM
    Hi all!
    The guy rebuilding my engine said the rocker arms have excessive side play, and he'd like to machine new spacers. Is there a recommended clearance between rocker arm and the spacer?
  2. slantsixdan
    slantsixdan =..=
    6,458
    1568
    Jan 7, 2007
    Vancouver BC
    Local Time:
    6:10 PM
    This is not a very crucial dimension. 1mm will be fine.
    • Like Like x 2
    • TAK65
      128
      67
      Aug 17, 2015
      Helsinki
      Local Time:
      4:10 AM
      Thank you Dan! 1 mm sounds a lot but I understand the arms need to "float" a bit on the shaft.
    • famous bob
      famous bob mopar misfit FABO Gold Member
      15,439
      5591
      Aug 14, 2011
      okla
      Local Time:
      8:10 PM
      if it has rocker shaft oiling, too much can affect oil pressure.
    • Charrlie_S
      Charrlie_S Well-Known Member
      2,777
      663
      Oct 17, 2005
      Silver Springs, FL
      Local Time:
      9:10 PM
      Not on a slant six. Rocker oiling is controlled by the hole(s)/ groove, in the rear cam bearing journal. Also the clearence between the arm and the shaft will have a larger effect on rocker arm oiling then the side play.
    • KosmicKuda
      KosmicKuda FABO Gold Member FABO Gold Member
      1,673
      496
      Jan 15, 2011
      N Ohio
      Local Time:
      9:10 PM
      Yeah, South of the Canadian border that's about 40 thou. Is there an actual spec for side clearance?
      If he's really concerned it would be easier to adjust by using shim washers but I wouldn't worry about it unless it's excessive.
    • famous bob
      15,439
      5591
      Aug 14, 2011
      okla
      Local Time:
      8:10 PM
      never owned a slant, don`t know a thing about them !!
    • Daves69
      Daves69 FABO Gold Member FABO Gold Member
      4,751
      2861
      Feb 20, 2011
      WestOfChi
      Local Time:
      8:10 PM
      FWIW, If you cant find an actual spec for it, I think 440source suggests .015"-.030" for their BB rockers.
    • slantsixdan
      slantsixdan =..=
      6,458
      1568
      Jan 7, 2007
      Vancouver BC
      Local Time:
      6:10 PM
      There's no spec.
      Sure, but the OP is in Finland, where they use the Metric system.
      Not that I've seen.
      • Like Like x 1
      • Killer6
        Killer6 Well-Known Member
        2,385
        790
        Mar 9, 2015
        PA
        Local Time:
        8:10 PM
        The shaft pedestal/hold-down side of all the rockers is wide open, there is no "oil pressure loss" issues w/side clearance, the design of the system with the feed holes at the
        point of contact/load controls the oil flow. The valve tip rocker pad is generous and easily accommodates the stock amount of side play. The only thing to possibly be gained
        would be to have the pushrod ball adjuster perfectly aligned w/the lifter cup to get the most lift and least pushrod deflection, but unless you're goin' for the gold w/killer VS's,
        it would simply be an OCD's labor of love. That said, slanty rocker shafts are the same dia. as BB mopar, and selective shims are available.
      • MAGA
        MAGA Member
        10
        13
        Dec 24, 2019
        Oregon
        Local Time:
        6:10 PM
        What did you end up doing? I’m noticing the same issue with my rebuild. Advice?
      • MOPAROFFICIAL
        MOPAROFFICIAL Well-Known Member
        5,065
        4045
        Jun 1, 2016
        Beach
        Local Time:
        6:10 PM
        They can make a clacking noise if they arent centered along with a lot of side clearance.
        Shoot for .015 side clearance
