I looked those up they are for a big blockComp Cams rollers. Note the offset
:View attachment 1715244008
It may be a generic photo but nope. Small block. Did you look up the right ones? These are the ones I looked up.I looked those up they are for a big block
Ok I guess I looked up the wrong oneIt may be a generic photo but nope. Small block. Did you look up the right ones? These are the ones I looked up.
http://www.manciniracing.com/manroc...ing.com/parts/cca-1622-16/overview/make/dodge
^^^^....as above.
So, you can shim the shafts up, get different pushrods, or put on adjustable rockers; adjustable rockers don't have to be rollers.
If you can tell us how much lift the cam has, everyone can make a better recommendation. Since you don't want the best (in other words, don't need to spend for the pricey ones...), have you looked into buying a set of the 273 adjustable rockers?
How are you using this car? Cruiser or all out drag race or what? Again, that will impact the recommendations.
Not going to drag race but I want it to run good if I need it to and cruiser most^^^^....as above.
Do you have an example of this?Research roller rocker geometry before you make a decision on any rocker. You'll be glad you did. Searching the archives on FABO is a good place to start.
Valve train geometryDo you have an example of this?
This is a big block rocker pic. Small block roller rockers don't have any offset.Comp Cams rollers. Note the offset
So what you are implying is that the hydraulic lifters are out of their range of adjustment, and they are holding the valves open, and she won't start. Is that it?Someone did a valve job and shaved the heads and that caused a low compression on a few cylinders loosened up the rocker shaft compression came up so that's why I need roller rockers
Well, then the 273 rockers might be just fine for that .474" max lift. You'll still need to change pushrods though to use those.Not going to drag race but I want it to run good if I need it to and cruiser most
Shim the shafts! I know the oil goes through the shaft.Oils thru the shaft push rods are solid
I don't even think he knows what you're talking about when you say shame the shafts.^^^^....as above.
Whatever it takes of course if indeed that is the problem. It's always nice to solve something over the internet.Not those shims, he really needs to get the B3RE spacers if he is going that route...
