run of the mill or Something special?
Suspension, Steering and Chassis
  1. BigRichieO
    BigRichieO Colorado Mopar
    597
    16
    Jul 16, 2006
    Arvada, Colorado
    Local Time:
    2:35 AM
    I went to the junkyard yesterday and picked up some parts. I found a manual steering box that was in a '68 Dart 270. Can anyone tell me if the steering box I got is a quick ratio box or just your normal everyday manual steering box.
    The cast numbers are 2537349 then the is a larger 3 directly under the 734, there is also a KCP circled with an oval shape, a very small 67 and also a DPCD? On the front in the little nipple area there is a 737 and last on the cover plate someone has stamped a D1211G. Not sure if you can see all this from the pictures, but any help is apreciated, thanks!!
    Rich
  2. BigRichieO
    597
    16
    Jul 16, 2006
    Arvada, Colorado
    Local Time:
    2:35 AM
    I doesn't look like anyone knows if this is a good one or not so I'll change my question a little bit. What are the cast numbers for the good manual steering boxes? Thanks
  3. GЯEENHOЯNET
    GЯEENHOЯNET Well-Known Member
    110
    0
    Feb 28, 2008
    Local Time:
    3:35 AM
    nothin special about it. just looks like your average small sector manual box.
